Page 1 of 2
Trickle charger
Posted: Wed Jun 14, 2017 1:35 pm
by Seacube
I'm not going to be using my car for a few weeks. Any recommendations for a decent trickle charger? Even better if I can use the cigarette lighter socket.
Re: Trickle charger
Posted: Wed Jun 14, 2017 2:03 pm
by don0301
I use CTEK, cracking bit of kit
I use the CTEK MXS 5.0
Re: Trickle charger
Posted: Wed Jun 14, 2017 2:06 pm
by daytonamart
don0301 wrote: ↑Wed Jun 14, 2017 2:03 pm
+1, great piece of kit. It monitors the battery so only charges when it needs to unlike a trickle charger which is constantly on.
Re: Trickle charger
Posted: Wed Jun 14, 2017 2:07 pm
by don0301
If the C7 is like the C6 (which I would be surprised if it isn't)
You're supposed to charge the car from the charging points in the engine bay, it's not just a straight forward charge across the battery or lighter socket (correct me if I'm wrong)
Re: Trickle charger
by don0301
The CTEK also "conditions" your battery, recommended every year.
Re: Trickle charger
Posted: Wed Jun 14, 2017 2:17 pm
by marc1
Hmm, wouldn't mind knowing the charge points for the B7 too. I use a CTEK MXS 5.0 for another car, but am likely to put one on a B7 too. It would work best for me if I can charge from the battery in the boot, rather than terminals under the bonnet.
Re: Trickle charger
Posted: Wed Jun 14, 2017 2:37 pm
by daytonamart
marc1 wrote: ↑Wed Jun 14, 2017 2:17 pm
marc, the charge points recommended are under the bonnet. one on the battery and the other on the post to the right of the charging points.
Re: Trickle charger
Posted: Wed Jun 14, 2017 3:03 pm
by marc1
Cheers mate.
Re: Trickle charger
Posted: Wed Jun 14, 2017 7:48 pm
by harrier
+1 for CTEK MXS 5.0 - excellent device costing from about £55.
It is easy to attach to the terminals under the bonnet (idiot proof directions and order of operation on the bag it comes with) and you can run the cable discreetly out from under the bonnet and away. It can monitor/trickle charge and also refurbish the battery.
Re: Trickle charger
Posted: Wed Jun 14, 2017 8:21 pm
by chunky79
Another +1
Re: Trickle charger
Posted: Thu Jun 15, 2017 12:58 pm
by Seacube
Thanks for all the recommendations - looks like there's total unanimity!
Have ordered my CTEK MXS 5.0 (£62.50 - Amazon) and located the charge points to the left of the engine. It seems like it's important to charge only from the charge points and not direct to the battery as the charge points go via some circuitry that protects the electrics.
Re: Trickle charger
Posted: Thu Jun 15, 2017 1:01 pm
by marc1
I wonder if they do extension cables for them. I need to have the charger towards the back of the car and the charging points are under the bonnet.
Re: Trickle charger
Posted: Thu Jun 15, 2017 4:38 pm
by GrahamS4
Another +1. Yes they do extensions.
Re: Trickle charger
Posted: Thu Jun 15, 2017 5:05 pm
by marc1
Cheers Graham, I'll get in contact with them.
Re: Trickle charger
Posted: Thu Oct 11, 2018 7:04 am
by uplandsway
Hi,
Do you have to go to the battery / battery charging point or is it possible to go into the cigarette lighter socket ?
