Confused on different rolling road figures
Posted: Thu Dec 01, 2016 10:35 am
by Rs63855
Guys after some info please
So after seeing many c7 rs6 claims getting around 600bhp stock! Why did mine only get 575bhp with full miltek turbo back and race plugs. ? Then had it staged 2 and we got 685bhp 740 torque. But on vbox it did 100kph-200kph in just 6.7 seconds witch the 750bhp tuned rs6's are getting. Confused to hell lol
I was told the company that did mine there machine is calibrated perfectly using lab equipment. Hence figures are what there ment to be. Hence why the stock cars They dyno are always really close to the claimed stock figures and never over more than 5-10bhp....
Any input on this guys?
If that's the case does that mean if I go to a different rolling road my car will be getting 730-750bhp only because there dyno won't be as accurate?
Re: Confused on different rolling road figures
Posted: Thu Dec 01, 2016 10:42 am
by kent_andy
where did you have your run? I ran my tuned C6 on several dynos and can tell which ones are similar and those that over/under read
Posted: Thu Dec 01, 2016 10:52 am
by Rs63855
Unicorn developments mate. They have a really good reputation all guys recomend them on Audi-sport forum. I do trust his figures and he defo noes his stuff very well knowledged guy. But just want to see what people's thoughts on this is. If he wanted to he could of easily gived me false readings to make me more happy lol but he is a honest guy.
Posted: Thu Dec 01, 2016 10:57 am
by Puggie
A dyno is a tool to measure the difference in power output when you change something in an engine.
Dyno to dyno their results do vary, any you can also fool many dynos to give the readings you want. I like dyno dynamics rolling roads, I have one local and the results are very repeatable (I can dyno the car 6 months apart and get results within a couple of bhp). I have used a hub dyno before as well, that particular one was much better for getting numbers to use down the pub (it read about 8% higher than the dyno dynamics), especially at the end of the session as it read significantly higher after 3 hours use (the same map measured 12bhp more after 3 hours mapping)!
Posted: Sat Dec 03, 2016 9:19 am
by kent_andy
there are so many factors which can influence the result of a dyno, temperature, air flow, how long the dyno has run for on that day, tyre pressure etc, the key is how the car feels on the road. Pretty sure you can use
Vagcom to measure your flow and then calcualte from there the output, i cant remember the exact measure meant but its meant to be more accurate.
Posted: Sat Dec 03, 2016 10:32 am
by MikeFish
The maximum mass air flow will be about 80% of the BHP eg if you have a mass air flow of 400g/s this works out to be about 500bhp.
On the B7
Vag Com reads the air flow for only one bank so you have to double it. Probably the same for the C7.
Using a Bluetooth OBD dongle on the C7 I couldn't get the mass air flow data.
Posted: Sat Dec 03, 2016 10:38 am
by MikeFish
So a standard RS6 with 553 bhp should have a mass air flow of around 442g/s. A PE should see about 478g/s
To convert your maf figure to power divide by 0.8.
Posted: Sat Dec 03, 2016 11:43 am
by chunky79
Why is this in the MRC section?
Posted: Sun Dec 04, 2016 8:38 am
by bam_bam
Because the OP is a front bottom.
Posted: Thu Dec 08, 2016 4:52 pm
by johneroberts
i like your style
Posted: Thu Dec 08, 2016 6:43 pm
by chunky79
johneroberts wrote:Because the OP is a front bottom.
i like your style
I bet when you started this site, you'd never have thought that someone like bum_bum will have been allowed on for so long.
Posted: Thu Dec 08, 2016 7:14 pm
by Eddie555
chunky79 wrote:johneroberts wrote:Because the OP is a front bottom.
i like your style
Yea racist pigs that entertain themselves with other peoples Mums giant black bottom toys shouldn't be allowed on public forums.
Posted: Thu Dec 08, 2016 7:17 pm
by chunky79
Racist
Posted: Thu Dec 08, 2016 7:29 pm
by Eddie555
chunky79 wrote:Eddie555 wrote:
Yea racist pigs that entertain themselves with other peoples Mums giant dark shade of grey bottom toys shouldn't be allowed on public forums.
Non Racist
Corrected.
Posted: Thu Dec 08, 2016 8:28 pm
by TTE Si
The 100-200 KMH time you quote is that from performance box? If Is.. is it verified and corrected time?
Just I know from much 100-200 testing how important certain details can be.
