Page 1 of 10
Lowering and / or spacers
Posted: Sat Feb 06, 2016 10:17 am
by Andy_W
I'm just wondering who has lowered their C7s or fitted modist spacers. There seems a few inconclusive threads on here. I just want to improve the stance really. I love my 21 black finished wheels but it does sit a little high compared to other cars I've had. At the same time I don't want to make it uncomfortable or have any rubbing or non OEM feel to the car. There are several brands of springs out there from reputable brands such as H&R etc.
Has anyone on here done either of the above and any recommendations?
I have dynamic pack not air suspension..
Re: Lowering and / or spacers
Posted: Sat Feb 06, 2016 12:24 pm
by mjwebb48
Ive got a kw lowering kit and spacers sat in box in the garage waiting for the weather to get better and I may fit them. Bought it all before car arrived. Only worry I would have with spacers is more stone chips etc on the front of rear arches. Rears could do with being spaced out as they sit inside the arches by quite a way.
Posted: Sat Feb 06, 2016 1:13 pm
by MikeFish
I will decide on spacers once the new wheels are fitted. I am planning on lowering it soon after it arrives but there are others on here that have done it already. Sounds like you've already read the previous threads about it though.
I guess it all depends on how much you lower it by. H&R have springs at 2 different heights and KW do an adjustable height spring kit. KW also do a proper ground scraping set of springs under a different brand name (gepfetert or something like that, the uk distributor runs and rs6 ).
Posted: Sat Feb 06, 2016 10:51 pm
by Andy_W
MikeFish wrote:I will decide on spacers once the new wheels are fitted. I am planning on lowering it soon after it arrives but there are others on here that have done it already. Sounds like you've already read the previous threads about it though.
I was only thinking 20mm ish. Just enough to loose the arch gap without compromising ride or any rubbing etc. Assuming that's possible. Or spacers may do the same without lowering but can't find much info really. Lots of great photos on the web but no feedback on the results. I've lowered a few cars before and if anything the ride had improved but they were less modern cars!
Posted: Sat Feb 06, 2016 11:13 pm
by MikeFish
H&R do a 20mm drop set of springs, part number 28828-1.
Cheapest place I can find is on ebay from Germany for just under £200. I haven't translated this page to check everything, this is just to give you an idea:
http://www.ebay.co.uk/itm/H-R-Federn-20 ... SwDN1UPlkn
Posted: Sun Feb 07, 2016 12:59 pm
by MartayMcFly
I don't remember who posted this, or what thread it was in, but this is pretty much perfect to me. H&R springs, not sure about spacers.
Posted: Sun Feb 07, 2016 2:27 pm
by Andy_W
MartayMcFly wrote:I don't remember who posted this, or what thread it was in, but this is pretty much perfect to me. H&R springs, not sure about spacers.
That was the look I had in mind but think I read that there was some rubbing on this one? It would be good to know someone that can say for example I've got xyz fitted and no rubbing etc.
Posted: Sun Feb 07, 2016 3:28 pm
by D8vil
I was going to fit some 20mm spacers but have decided to fit new wheels (just saving). If another wants them £120 posted, bought from another momber
Posted: Sun Feb 07, 2016 4:40 pm
by mjwebb48
Andy_W wrote:MartayMcFly wrote:I don't remember who posted this, or what thread it was in, but this is pretty much perfect to me. H&R springs, not sure about spacers.
I have got the set up off that car in my garage. kW adjustable Spring kit 15mm spacers rear and I thinks it's 12 MM front.
Posted: Sun Feb 07, 2016 4:45 pm
by MikeFish
I was going to say I thought he sold them here. I just missed out on them.
Posted: Sun Feb 07, 2016 4:54 pm
by Zeebuilder
Did Paul not mention he was maybe going to try lower the Air on is model using vdrs? Anyone heard of this??
Posted: Sun Feb 07, 2016 5:03 pm
by MikeFish
Zeebuilder wrote:Did Paul not mention he was maybe going to try lower the Air on is model using vdrs? Anyone heard of this??
Yes, I've read about this a few times now, you can lower the air suspension by up to 17mm using VCDS. You could probably go lower but that is the lowest within the predefined limits.
Unfortunately it's not that easy with DRC like the OP has.
Posted: Sun Feb 07, 2016 10:29 pm
by Paulm
Yeah I have been dragging my heels a bit. Want to measure camber before I lower it to see the difference. Looking at the standard car it is either zero or edging towards positive camber which won't help under steer. Lowering it should enduce some negative camber.
Posted: Sun Feb 07, 2016 10:46 pm
by Zeebuilder
OK Paul. U be guinepig and I'll follow once all good!! Nice plan lol
Posted: Sun Feb 07, 2016 10:49 pm
by MikeFish
Paul is taking ages, you should try it first!
