OEM RS6 C7 PARTS?
Posted: Sun Jan 18, 2015 1:05 pm
by seb de la run
do you have a website or adress, because, i test with the
Vag Com and i have problem on ignition coil : message engine misfire.
in the same time i have a message dysfontionnement start and stop..alternator problem??
so i need :
8 ignition coil
8 spark plug
1water pump
thanks you for your helps
Re: OEM RS6 C7 PARTS?
Posted: Sun Jan 18, 2015 1:54 pm
by LittleDevil
Do you maybe have error codes from vag-com?
Kind Regards
Posted: Sun Jan 18, 2015 2:34 pm
by MikeFish
Isn't it still under warranty from Audi? Why don't you just take it back to the dealer?
Posted: Sun Jan 18, 2015 2:42 pm
by seb de la run
my dealer is in france and i live in reunion island 10 000km.
the reunion dealer is a robber...is price is too much expansive.
so could you help me?
Posted: Mon Jan 19, 2015 5:19 am
by seb de la run
nobody have a good address to order oem parts?
Posted: Mon Jan 19, 2015 7:10 am
by LittleDevil
seb de la run wrote:nobody have a good address to order oem parts?
I send you private message. Check on the top of the website.
Posted: Mon Jan 19, 2015 8:29 pm
by BFT - John
Hmmmm you are tuned. Make sure you don't have a map that is causing these issues.
Posted: Tue Jan 20, 2015 5:12 pm
by seb de la run
my code default : sorry for my bad english
p0301 00 (237)
missfire cylinder 1
i have the problem just when the rs6 is tick over...
if rhe engine idle more than 15sec, i have the EPC and the motor light...and the car is jerky
but if i drive under 15sec the engine idle, i have no problem..the car is perfect.
i remove the map.
i test ignition coil 1 by 4 and no problem
i test spark plug and no problem
injector?
but the problem is just when engine idle more than 15sec...
Posted: Wed Jan 21, 2015 10:57 am
by BFT - John
How have you removed the map?
If you have removed the map I suggest ensuring all ECU's are wiped off DTC's and try again.
Posted: Wed Jan 21, 2015 7:33 pm
by seb de la run
many thanks for your message.
i must to remove the tune, but i dont understand this :
i must to drive without dtc?
or i remove the tune when the dtc is off...
sorry but i choice mathematic in option...and must to choice english !!!
