Engine temperature readings
phol
Post by phol » Mon Feb 19, 2024 10:50 am
Is it normal to get different readings from the two temperature displays? The bars on the left side of the dash quickly rise to 90 with the associated rev limit increase, but the temp reading on the lap timer screen takes much longer to increase. There can be a differential of 30 degrees at times. Are they taking readings from different sensors? I'm always gentle with the car from cold but I'm not sure which one indicates the engine is fully warmed through.
C7 RS6+
noidea
Re: Engine temperature readings
Post by noidea » Mon Feb 19, 2024 11:59 am
The one on the dash is water temperature, that will always get to temp the quickest.
The other is oil temp and will take longer, I always wait until it gets to 90 degrees before loading the engine too much.
Sent from my Pixel 6 Pro using Tapatalk
phol
Post by phol » Mon Feb 19, 2024 1:15 pm
thanks, i had suspected it would be something like that
C7 RS6+
