DRC refill
Tadass910
DRC refill
Post by Tadass910 » Fri Oct 14, 2022 5:13 pm
Hello, anyone did it? Any ideas how much it can cost if it’s only front? And if all needed? Thanks
Daveperc
Re: DRC refill
Post by Daveperc » Fri Oct 14, 2022 5:44 pm
Since the DRC circuits are diagonal across the car I fail to see how you think "it's only the front"!! :drink: :drink: :bigwave:
Revilo
Re: DRC refill
Post by Revilo » Fri Oct 14, 2022 8:23 pm
It’s about £200-250 at Audi to replace fluid and pressurise
Rich85
Re: DRC refill
Post by Rich85 » Sat Oct 15, 2022 10:59 pm
Had mine done under warranty. As mentioned it’s a diagonally linked system with 2 valve assemblies at the rear and these can get damaged when pressure is lost.
I had knocking from the front right and rear left. Dealer refilled and pressurised (over 20+ bar) and has been OK since, so I may have been lucky and not damaged anything.
Tadass910
Re: DRC refill
Post by Tadass910 » Sun Oct 16, 2022 9:17 am
Thanks everyone for information, I have this knocking https://youtube.com/shorts/-I4jIfXouSs?feature=share
https://youtube.com/shorts/x38UUMcTA6I?feature=share
Not sure is it drc or something else, and this noise I get when I turn to the left hard when one wheel especially more higher than other, same sometimes happens when I turn to the right also when car not in horizontal position and one wheel higher than others
morski
Re: DRC refill
Post by morski » Sun Oct 16, 2022 12:21 pm
Check your arb links. can also cause a knocking noise.
Tadass910
Re: DRC refill
Post by Tadass910 » Wed Oct 19, 2022 7:56 pm
Thanks for mentioning that, I definitely going to Audi dealer, that I have that noise and point them about that it could be drc refill time or these arb links. Or should I not mention them anything just tell that I have that knock sound, I can show on a video
P.S you mean those arb links in a picture I posted?
Or it’s this item https://m.autodoc.co.uk/ridex/8101055
morski
Re: DRC refill
Post by morski » Wed Oct 19, 2022 10:29 pm
Yes those are correct. As you have DRC part no is 4H0411317C. I try to use a decent brand such as Lemforder, Febi, Meyle
Tadass910
Re: DRC refill
Post by Tadass910 » Thu Oct 20, 2022 10:25 am
super7
Re: DRC refill
Post by super7 » Sun Oct 23, 2022 10:44 am
Same for me… I had mine done under warranty. It was only 2 bar under but had a noticeable knock on my rear left. Back up to 20+ bar and it went. Had the same issue with my RS4 B7. Tech at Audi said the knock is perfectly normal on DRC. Although my OCD on noises can’t cope with it!
Tadass910
Re: DRC refill
Post by Tadass910 » Tue Oct 25, 2022 2:52 pm
So tech Audi said knock is perfectly normal? But you shouldn’t hear any knock if everything ok
stuartbarriskell
Re: DRC refill
Post by stuartbarriskell » Thu Nov 03, 2022 10:58 pm
Agree 100%... the suspension shouldn't knock at all if everything is sound.. I've just found that out when I had a strut replaced the whole system drained and refilled..not a sound from it.
Sent from my SM-G998B using Tapatalk
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Tadass910
Re: DRC refill
Post by Tadass910 » Wed Nov 09, 2022 4:41 pm
I had a strut replaced.
Can you tell me more pls?
stuartbarriskell
Re: DRC refill
Post by stuartbarriskell » Fri Nov 11, 2022 12:46 am
I'm mentioned here, what do you need to know
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Tadass910
Re: DRC refill
Post by Tadass910 » Sun Nov 13, 2022 11:10 am
:thumbs: Thanks
Users browsing this forum: Daveperc and 42 guests
