AUDI RS6 C7.5 with C8 22” x 10.5” ET19 GENUINE ALLOYS
Re: AUDI RS6 C7.5 with C8 22” x 10.5” ET19 GENUINE ALLOYS
Thanks for information m8, enjoy your new rims)
Hi,
I have just purchased set of these new unused to for my 2017 C7 and then panicked when saw offset different but your post has thankfully made me feel better lol... still all ok? Do you have any spacers fitted as i currently have 15 front and 20 back on my standard 21's? Cheers and thanks again
Hi, if you have purchased the alloys complete with the standard fit tyres I think you may well have issues because of the profile being 30, hence why I went for the 25 profile, spacers are a definite NO NO, these alloys are the absolute maximum width and offset without doing any body modifications from standard.
Hope this helps, best of luck.
Well i followed your lead and took the plunge too... must say look awesome and ride not too bad... my only quibble is a slight rub from front when goin over big dips but noticed a bolt on underside of arch which im goin to remove as rekon that the culpritt. Cheers again for the write up, helped alot
Wheels suit the car colour so well. Nice job.6081ozzy wrote:Well i followed your lead and took the plunge too... must say look awesome and ride not too bad... my only quibble is a slight rub from front when goin over big dips but noticed a bolt on underside of arch which im goin to remove as rekon that the culpritt. Cheers again for the write up, helped alot
Really nice, they make the car look very stealth, I didn’t experience rubbing on the fronts, not sure why.
Did you go for the 295/25/22 tyres ? Cant tell off the pics.
I was chuffed to bits with how well they filled the arches, it almost makes the standard 20’s and 21’s look out of place without spacers.
Well done, glad I could be of assistance.
Yes same tyres... removed the bolts and all good now, they only fix arch liner and plenty others holding it so all good... your right they fill the arches spot on... cheers again
I want to see a blue car with them on now
Hi pal
Can I just say that your research is fantastic.
Iam just about to purchase the same alloys and I will be putting on 295/25/22 Michelin pilots.
I presume spacers are a big No No and is there any other advice hints or tips that I need to No before fitting.
Your article is absolutely fantastic and a credit to your enthusiasm for the brand.
I look forward to your response.
Thanks again pal
Jonathan
Thanks again pal
Jonathan
Hi all
Can anybody tell me where the best place is to buy the tyre pressure sensor valves for a 2016 RS6.
Thanks in anticipation
Maybe Audi dealership
I did think that however I’ve read previously that they are extortionate from Audi.
Here you go, these are the correct ones, pre coded and genuine audi, they’re less than £100 all in for all 4.
https://www.ebay.co.uk/itm/403412437364 ... SwLjdh4aMf
Yes very expensive from Audi, I was quoted over £500 for the 4 and when I was checking with audi they also confirmed that this was the exact correct part number.
So all is better than very good
Top man thank you so much
In my opinion 22 is too big, 21 inch for c7 is top noch
