Fuel Issue
Fuel Issue
Hi guys,
Probably been asked before but I'm in a mad rush. Had my C7 almost two years and I've only used V-Power to fill up. I'm concerned now that I won't be able to get any with the tanker driver shortages and I don't have enough in the tank to go searching around. What is the minimum grade (RON) I can safely use without causing any issues please?
Thanks in advance.
Thanks in advance.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: Fuel Issue
Absolutely fine. Have a look on the inside of your fuel filler. It says 95ron minimum which is normal unleaded. Just go back to super unleaded at the next opportunity
Re: Fuel Issue
Thanks guys, I thought 98/99 but it does say 95 minimum on the fuel cap. Absolutely no fuel available anywhere near me at the moment though so I'm stuck at home with the Mrs.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: Fuel Issue
Goverment is a shambles for creating this mess
Re: Fuel Issue
Just to confirm guys,
My warranty wouldn't be invalid if I use 95 RON as it states it's the minimum requirement in the filler cap?
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: Fuel Issue
You could always put normal unleaded in with an octane booster if you are worried about it
Re: Fuel Issue
Managed to get to station with Esso Supreme + 99 RON so got £35.00. Relieved.
I do wonder if they changed the rule to let you fill up to max it would ease the panic a bit?
Cheers all, much appreciated as always.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
