HVAC smell...
jamesbilluk
HVAC smell...
Post by jamesbilluk » Tue Jul 30, 2019 1:57 pm
Hi all,
Sorry another question...
I've started to notice, when first starting up the car, there's a smell of sulphur/egg coming from the vents, this does go away, but seems to come back, could this be coming from th epollen filter, or maybe the catalytic converter into the vents?
James
2013 C7 RS6 (in a shade of red I'm still trying to identify..)
Lig
Re: HVAC smell...
Post by Lig » Tue Jul 30, 2019 4:12 pm
Hi James,
Never smelt this so cant really help, but yes sulphur usually is the cats, however the pollen filter is a 2 min easy job to replace and costs about a tenner, so worth changing.
Cheers,
Lig.
jamesbilluk
Re: HVAC smell...
Post by jamesbilluk » Tue Jul 30, 2019 8:29 pm
Cheers Lig, have purchased a pollen filter, will give that ago, seems very strange when it comes and goes, I thought I was going crazy, but the other half noticed it too. Bit annoying as the car smells very nicely of leather!
Lig
Re: HVAC smell...
Post by Lig » Wed Jul 31, 2019 8:52 am
Yeah, see how it goes. Its unlikely that the pollen filter will fix it (unless maybe there is no filter in there)??? But if it continues after a few miles, I would take it back for the dealer to check out. Could it be that the dealer has had it for a while and so it hasn't seen much use and after you have started to use it and put on a good few miles it might just clear?????!!!!
I am sure it will have at least 3 months warranty....??
Cheers,
Lig.
jamesbilluk
Re: HVAC smell...
Post by jamesbilluk » Wed Jul 31, 2019 12:33 pm
I think the pollen filter sorted it, this is the old one on the left that came out, compared with the new one, no idea when this was last changed! It seems to have made the the system work less hard too,
wildbore
Re: HVAC smell...
Post by wildbore » Wed Jul 31, 2019 4:19 pm
Sounds most likely to be bacteria breeding in the A/C ducting. A sour, mouldy smell is quite common at this time of year. They sell "Air Conditioning Bombs" in Halfords that can often solve the problem, but they don't always work.
You can minimise the possibility of this re-occurring by never turning the A/C off, but you can still get it, even then.
jamesbilluk
Re: HVAC smell...
Post by jamesbilluk » Thu Aug 01, 2019 11:56 pm
Second day of driving, and the smell seems to have dissipated :) Have purchased the Autoglym Air conditioner bomb though just to make sure..
zaina1
Re: HVAC smell...
Post by zaina1 » Tue Jul 07, 2020 2:25 pm
You should contact car service company or you may contact to ac maintenance in Dubai otherwise your ac became damaged.
WalkeRS6
Re: HVAC smell...
Post by WalkeRS6 » Sun Jul 12, 2020 12:49 am
If it is persisting... I have an alternative solution.
Buy a tin of Dettol "All in one" spray.
Remove pollen filter.
Run vehicle.
Set fan to max fan & cool with air con on, but no re-circ.
Spray Dettol in short bursts (3-4) into the gap that housed the pollen filter.
Cycle through the air vent options and use a 1-2 bursts of spray for each air vent setting.
Repeat above with re-circ on.
Install new pollen filter.
Run vehicle & get it hot (If it isn't already).. Then let it do its thing for at least 5 mins after, air con on, but - Max heat and doors closed, to dry out the system a bit.
it will take 1-2 days driving for the treatment to work all the time, but the stink should go after that....
I've had good results doing the above with various makes of cars & vans.
2015 RS6 Avant.
eng33
Re: HVAC smell...
Post by eng33 » Mon Aug 03, 2020 9:49 pm
Just had the exact same issue on my 2016 Allroad, I also convinced myself if was a leaking cat / exhaust or the HVAC system, and removed the pollen filter but this was clean and odour free. The fix? The washer bottle! Washer fluid had gone stagnant, after draining / flushing out, and refilling with fresh water and concentrate, smell completely gone. Yes, i wouldn't have thought it was this either! Still not really sure how it was possible, but the washer bottle filler is right next to the HVAC intake on C7 A6's, so maybe the cap was leaking slightly.
Current:-
2023 C8 RS6 Performance Carbon Vorsprung
Previous:-
2022 C8 S6 Avant Vorsprung
2021 C8 A6 3.0TDi Allroad Vorsprung
2017 C7 RS6 Avant Performance
2016 C7 A6 3.0TDi Allroad
2011 C7 A6 Avant 3.0TDi SE
2002 D2 S8 Final Edition
2000 Mk1 TT 225 Coupe
1999 D2 A8 4.2 Quattro Sport
1991 Porsche 964 RS Lightweight
1933 Ford 1/2T Pickup Truck
Users browsing this forum: No registered users and 194 guests
