15mm spacers
15mm spacers
As title suggests, I am thinking of fitting 15mm spacers all round on my 21" wheels. Do i need longer bolts or are the standard ones fine?
Re: 15mm spacers
You will defo need longer bolts ideally 15mm longer. I think standard length is 27mm so look for something like 42mm.
Re: 15mm spacers
I'm thinking of doing the same despite struggling already with the width of this weapon
Are 15mm on all 4 corners OK or maybe go 12mm at the front?
Any thoughts and pics would be great.
Shane
Current
2017 C7 Nardo RS6 Performance
Gone:
C43 AMG Coupe
Black E92 M3
Daytona B7 RS4 Saloon
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Cavalier 1.8 lsi
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: 15mm spacers
Mike's info on bolt length is correct as far as I remember - but beware as that is the thread length up to the hub, not including the hub at the top of the bolt.
It was wrongly shown on some sites, notably H&R - I haven't checked recently.
Re: 15mm spacers
I got 15mm on the back even when it was lowered. I think 15mm may be too much at the front though. Difficult for me to judge as mine was very low at the front and with OEM wheels I couldn't fit any spacers. Then when I raised it a bit I had other wheels on.
Re: 15mm spacers
Cheers Mike
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: 15mm spacers
I’ve literally just bought some McGard black series lockers. As Mike says the thread length is (I checked last week on the Febi website) 27mm of shank. So 42mm would be perfect McGard only listed 41mm as the closest so I’ve gone with them. With the 15mm spacers I got in the for sale on here, the threads on the bolts are 40mm. So I would say somewhere between 40-42mm will be fine. I will however report back next week when I’ve got them fitted.
It’s worth noting that the seat is a radius type. So make sure you get.
Craig.
Craig.
Re: 15mm spacers
Cheers Craig,crapbag wrote: ↑Wed May 27, 2020 2:51 pmI’ve literally just bought some McGard black series lockers. As Mike says the thread length is (I checked last week on the Febi website) 27mm of shank. So 42mm would be perfect McGard only listed 41mm as the closest so I’ve gone with them. With the 15mm spacers I got in the for sale on here, the threads on the bolts are 40mm. So I would say somewhere between 40-42mm will be fine. I will however report back next week when I’ve got them fitted.
Craig.
Can you post some before and after pics please?
Shane
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: 15mm spacers
Yeah no worries dude,
It’s currently at stock ride height. But that’s probably going to change to KW HAS
Re: 15mm spacers
Cheers, yep mine too on DRC so I'd bee keen to see if looks ok.
Shane
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Current
Gone:
C43 AMG Coupe
Black E92 M3
B6 S4 Saloon Tip
B5 S4 Avant
8L S3
Lexus IS 200
Vauxhall Astra 1.6l
Fiat Uno Turbo
Fiat 127 Sport
Ford Cortina MK5
Opel Kadett
Re: 15mm spacers
I had 15mm spacers all round, the rear was fine but had rubbing on the front. I’d say 12mm would be a better option on the front.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
Re: 15mm spacers
I'll be fitting 12 on front and 15 on back this weekend, I'm stock height on springs....I'll record before and after pics.....I ordered 43mm length bolts....hoping they're ok with 12mm spacers on front? Will run a few mm deeper....
Re: 15mm spacers
I'd be careful on the front - that's 4mm more projection through the disc than standard - check they don't bind - I tried to use bolts 6mm too long and it was too much.
Re: 15mm spacers
Noted.....will report back
