Thermostat open circuit p0597
l19ydm
Post by l19ydm » Tue Jan 02, 2018 5:05 pm
Hi All,
I have been having some issues with stop/start system not functioning and emissions light coming on. Had it diagnosed as above however the quote to replace the thermostat is for 6-7 hours work plus parts.
Has anyone undertaken this task or seen a how to writeup?
Many thanks
Sent from my EVA-L09 using Tapatalk
rtd
Re: Thermostat open circuit p0597
Post by rtd » Tue Jan 02, 2018 7:48 pm
This is interesting reading what issues are you having with the start/stop?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
l19ydm
Post by l19ydm » Tue Jan 02, 2018 8:45 pm
rtd wrote:This is interesting reading what issues are you having with the start/stop?
Message on dash that start stop function not available. I believe the emissions light comes on due to mixture, every time the light is on there are circa 100 of the above faults and 1 mixture fault on lambda probe.
Thermostat are normally a very simple Swap but without engine diagrams etc I am reluctant to tackle it.
Parkerdan
Post by Parkerdan » Wed Apr 08, 2020 9:15 am
Hi, did you have any luck with this after? I have same issue.
gazzars4
Post by gazzars4 » Sat May 30, 2020 2:37 pm
I’ve got the same fault come on this week
Sent from my iPhone using TapatalkImage
RS4 Sprint blue
gazzars4
Post by gazzars4 » Sat May 30, 2020 2:40 pm
That’s the codes stored with the EML on.
RS4 Sprint blue
Tadass910
Post by Tadass910 » Sat May 30, 2020 7:08 pm
I bet you car is facelift and you have 40.000 miles and such problems occur on your car, interesting, maybe you car is tuned?
gazzars4
Post by gazzars4 » Sat May 30, 2020 7:30 pm
Yes face lift and MRC tuned needing sorting might drop MRC a email see if they can sort the issue.
RS4 Sprint blue
Tadass910
Post by Tadass910 » Sun May 31, 2020 2:56 pm
Could be tune related who knows
Royclarke
Post by Royclarke » Tue Jun 02, 2020 1:39 pm
Mines stock and 42000 miles and had the start/stop fault and logged a coolant fault,they gone now now that I drive it everyday,I read somewhere with everything on these cars the batterie can start to drain and throw some faults,also when it goes into 4 cylinder mode the alternator can shut it’s self off because it uses more fuel to run it all the time
Tadass910
Post by Tadass910 » Tue Jun 02, 2020 3:19 pm
So what causing a problem then?
Royclarke
Post by Royclarke » Tue Jun 02, 2020 4:16 pm
Well for my car I’m guessing it was the batterie was draining and throwing so codes,I also read of this same thing happening on someone else’s car to
Tadass910
Post by Tadass910 » Tue Jun 02, 2020 7:56 pm
If i understand correct when batteries coming to an end you should receive a yellow light like this:
gazzars4
Post by gazzars4 » Thu Jun 04, 2020 8:08 am
Mine is the original battery still,looking back on invoices a new battery was quoted last year but wasn’t fitted. I’m going to get mine tested see if that is the cause interesting.
RS4 Sprint blue
Tadass910
Post by Tadass910 » Thu Jun 04, 2020 4:09 pm
Mine original battery 2014 year still kicking
Users browsing this forum: Google Adsense [Bot] and 51 guests
