Random Coolant and internal heater issue >>
Anth
Post by Anth » Tue Jan 28, 2020 9:05 pm
Hi guys ,
Hope everyone's very well. Random one, My coolant light has been saying "turn engine off check coolant" when this happens it is about a inch below minimum requirment. And again random when it decides to do it. The fix is - Turn the car back on give it some revs. The coolant fills back up to the prefect mark. Go figure! (I assume pressure related at this point) as also when I take the fill cap off again the level increases.
Anyway now the heat in the car cockpit is at best Luke warm,sometimes cold .. I have assumed this is linked. The car was dropping some coolant in December very little and Audi told me they tested it but can not find a leak or fault :audibash:
The 2 release values in the media attached could some kind person explain to me what there job is. Obviously under pressed on both lines labed 1 & 2 .
:idea: :idea: :arrow:
2017 C7 RS6 PE Nardo
2014 911 991 C4S PDK White
2013 M6 Cab Blk
2012 911 997 MK2 PDK Silver
2007 RS4 Cab Grey
morski
Re: Random Coolant and internal heater issue >>
Post by morski » Wed Jan 29, 2020 12:40 am
They are the AC charge points so nothing to do with the coolant. Some coolant is being lost somewhere but tracing it can be a pain as a lot of lines run in near impossible to see or reach areas. With your coolant topped off you should still be getting heat in the cabin unless you have an airlock as well. If you coolant is brownish and far from pinky/purple then your heater matrix could be clogged then thats a ballache
Anth
Post by Anth » Wed Jan 29, 2020 8:58 am
Coolant back full won't produce heat in the cabin . No brownish colour at all .
2013 M6 Cab Blk
2007 RS4 Cab Grey
mikep99
Post by mikep99 » Wed Jan 29, 2020 10:00 am
As mentioned above, it sounds like an airlock to me.
Had something similar on an old car after replacing the coolant.
Did Audi flush the coolant when they had a look? If not and its under warranty, I'd ask them to do this.
Mike
Anth
Post by Anth » Wed Jan 29, 2020 2:57 pm
Hi Mike,
Defo air related . Today re filled the system left the top off and the internal heat has returned. Is has dropped some coolant but this happened in December and Audi told me nothing wrong . My local Audi are horrendous not going to use again .
2013 M6 Cab Blk
2007 RS4 Cab Grey
morski
Post by morski » Wed Jan 29, 2020 7:00 pm
Must have a coolant drain in the past and not refilled correctly. Audi's need the system to be vacuumed and then filled so the vacuum draws the new coolant in.
Users browsing this forum: No registered users and 105 guests
