Hey,
I have an issue with my air con not turning on - it works sometimes but most of the time it won't let me turn the AC on. The red LED lights up when I press the AC button but won't stay on.
Booked into Audi but they can't see it till Friday, was wondering if anyone had any ideas that I may be able to fix myself.
Cheers,
Danny
Air Con issues
Air Con issues
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
Re: Air Con issues
Sounds like A/C gas pressure is below threshold and the pressure switch is cutting out the A/C. Therefore you will require an A/C recharge. First of all you’ll need to scan the car with a code reader/diagnostic machine, this will usually show a fault code relating to A/C system. Another thing to check is the condenser, which is visible through the centre front grille. Condenser is the one that takes the impact from stones off the road and causes minute A/C gases to escape.
Re: Air Con issues
Thanks. I couldn't see any codes but will get a regas done
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
