Black Badges
noidea
Re: Black Badges
Post by noidea » Tue Mar 12, 2019 11:06 pm
I have just bought a full set of black badges (front/rear rings and front/rear RS4 badge) from Audi for my B8 RS4. With a bit of discount under £120.
I have yet to confirm if the front rings fit as I have not popped the old ones out but they are the same size, as they are for a B9.
The rear RS4 badge is identical, the rear rings are 10mm longer and 2mm taller, I don't think that will notice once fitted. The front grill badge has a different fixing so l have removed the letters from both backing plates and swap them over with new double sided tape.
All good quality as they are OEM and quite inexpensive when you compare what is out there.
Sent from my Pixel 2 XL using Tapatalk
uplandsway
Re: Black Badges
Post by uplandsway » Wed Mar 13, 2019 4:09 am
Toffeebananas wrote:
Tue Mar 12, 2019 9:02 pm
RobRS wrote:
Tue Mar 12, 2019 6:51 pm
ab54666 wrote:
Tue Mar 12, 2019 4:00 pm
Anyone know where you can get a front badge in black (RS6 emblem)?
You can get them from these guys - https://www.ebay.co.uk/itm/Audi-A6-RS6- ... Sw4QdaeQJm
Although not cheap, they do look good :wink:
Have you bought any off this guy? Any pics of them fitted? Thanks
Thats where I bought all my badges / rings, front ring, rear ring, rear badge and front badge. :smile_smoking:
All look good and correct as far as my eyes can tell. :thumb:
Cheers,
Stevie F
2016 C7.5 RS6 Performance
noidea
Re: Black Badges
Post by noidea » Sat Mar 30, 2019 11:02 am
noidea wrote:I have just bought a full set of black badges (front/rear rings and front/rear RS4 badge) from Audi for my B8 RS4. With a bit of discount under £120.
All fitted, very happy with the results.
Toffeebananas
Re: Black Badges
Post by Toffeebananas » Sat Mar 30, 2019 2:07 pm
:thumbs:
dannyuk
Re: Black Badges
Post by dannyuk » Tue Apr 09, 2019 12:57 pm
Did you just apply heat to get the old badge off?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
noidea
Re: Black Badges
Post by noidea » Tue Apr 09, 2019 1:27 pm
dannya32 wrote:Did you just apply heat to get the old badge off?
Did you mean the rear ones?
If so yes, a bit of heat and fishing line if you have any.
Don't be tempted to pull them up at an angle as they can dig into the paint and cause a mark.
I then used glue and tar remover to get the rest of the sticky mess off that is left behind.
dannyuk
Re: Black Badges
Post by dannyuk » Tue Apr 09, 2019 1:34 pm
OK spot on, and did the kit from ebay come with sticky backs already?
2020 C8 RS6
2019 F90 M5
2017 C7 RS6
2016 F10 M5
2010 C6 RS6
noidea
Re: Black Badges
Post by noidea » Tue Apr 09, 2019 7:02 pm
dannya32 wrote:OK spot on, and did the kit from ebay come with sticky backs already?
I got mine from my local Audi parts dept.
Yes they did come all ready to fit.
