Is there an option to enable?
Yes, it's the same screen that tells you the oil temperature and has the boost gauge ie the most useful screen. What do you normally have it on?
Yup found it
You are wrong, they showed in both in hud as well in dash, you need to be in manual mode and use shift paddlesNortherner wrote: βTue Sep 19, 2017 6:40 pmWorked it out on the way home. The shift lights only show up on the heads up display and not the dash.
