Who knows maybe you ceramic are made from other material
Yep, this is how to solve the brakes squealing.Brooner wrote: ↑Mon Jun 26, 2017 7:54 amVery common most of this is caused by not using the brakes hard enough
My 13 plate RS4 has 26k on original steel disks 2nd set of pads I occasionally get a squeal a low speeds but only after a long motorway run or a lot of stop start driving
This is solved by taking the car on a quite road a stamping hard on the brakes several time with out locking up the brakes to clean the pad material build up that causes the squeal
A good stamp seems to have sorted mine for the time beingLukasPukas wrote: ↑Tue Jun 27, 2017 8:03 pmYep, this is how to solve the brakes squealing.Brooner wrote: ↑Mon Jun 26, 2017 7:54 amVery common most of this is caused by not using the brakes hard enough
Sometimes its called conditioning.
The method I used (that requires a nice long clear stretch of a road) is to brake hard, but evenly not locking the brakes (or abs kicking in) slowing from: 40mph to 20mph, 60mph to 20 mph, 80mph to 20mph, 60mph to 20 mph and 40 mph to 20mph.
Its great fun, but you look like a bit of a hooligan. Evens out the wear, which I understand gets a little uneven on these large brakes when not hammering them regularly!
Well I can live with squealing sound, it's not big deal
