OEM RS6 C7 PARTS?
OEM RS6 C7 PARTS?
do you have a website or adress, because, i test with the Vag Com and i have problem on ignition coil : message engine misfire.
in the same time i have a message dysfontionnement start and stop..alternator problem??
so i need :
8 ignition coil
8 spark plug
1water pump
thanks you for your helps
so i need :
8 ignition coil
8 spark plug
1water pump
- Trader (Expired)
Re: OEM RS6 C7 PARTS?
Isn't it still under warranty from Audi? Why don't you just take it back to the dealer?
my dealer is in france and i live in reunion island 10 000km.
the reunion dealer is a robber...is price is too much expansive.
so could you help me?
nobody have a good address to order oem parts?
- Trader (Expired)
I send you private message. Check on the top of the website.seb de la run wrote:nobody have a good address to order oem parts?
- 1st Gear
Hmmmm you are tuned. Make sure you don't have a map that is causing these issues.
2014 Audi RS6 4.0TFSi - Red/Sports Exhaust/21's
2004 Brabus SL K8 - Weistec Supercharger - 744bhp/753lbs Torque
2014 LR Defender XS
2014 RR Sport TDV6 HSE Dynamic
2003 Audi A8 4.2 LPG
Few others kicking around.
2014 LR Defender XS
my code default : sorry for my bad english
p0301 00 (237)
missfire cylinder 1
i have the problem just when the rs6 is tick over...
if rhe engine idle more than 15sec, i have the EPC and the motor light...and the car is jerky
but if i drive under 15sec the engine idle, i have no problem..the car is perfect.
i remove the map.
i test ignition coil 1 by 4 and no problem
i test spark plug and no problem
injector?
but the problem is just when engine idle more than 15sec...
p0301 00 (237)
missfire cylinder 1
i remove the map.
injector?
- 1st Gear
How have you removed the map?
If you have removed the map I suggest ensuring all ECU's are wiped off DTC's and try again.
2014 LR Defender XS
2014 LR Defender XS
many thanks for your message.
i must to remove the tune, but i dont understand this :
i must to drive without dtc?
or i remove the tune when the dtc is off...
sorry but i choice mathematic in option...and must to choice english !!!
