Wanted, C5 RS6 climate control and headlight switch
mattmitch
Post by mattmitch » Fri Jan 01, 2010 11:43 pm
Hi, as above really just need replacement climate control and headlight switch as mine are badly worn.
Matt
Mr V10
RE: Wanted, C5 RS6 climate control and headlight switch
Post by Mr V10 » Sun Jan 03, 2010 5:27 pm
Try www.A8Parts.co.uk, I use them a lot for my S8 and they are fantastic, they have just started doing C5 A6 models so your in luck.
spurtle
Post by spurtle » Sun Jan 03, 2010 5:43 pm
Seems to be quite common on these cars - I've seen three or four with similar problems. The trim around the front door handles seems to wear badly too. They've all been fine in my other Audis, even with twice the mileage.
Anyone know if the RS6 climate control head unit is the same as the A6? I think the headlight switch is different.
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
mattmitch
Post by mattmitch » Sun Jan 03, 2010 8:10 pm
Thanks chaps i,ll give them a try, I think the older audis had a slightly different finish on the plastic which was more hard wearing, the newer ones seem to be more rubbery which once marked starts to wear easily, it,s bloody annoying.
grizz
Post by grizz » Sun Jan 03, 2010 8:47 pm
I've got them in a 54 plate rs6 + i'm breaking , I'll have a look tomorrow for you .. grizz
Unit 20
0151 3366888
mattmitch
Post by mattmitch » Sun Jan 03, 2010 9:26 pm
Ok mate i,ll give you a ring in the morning.
