new RS4 b7 Discs (Phaetons Jhooked)
Posted: Mon Jun 11, 2012 12:09 pm
365x34 Phaeton Rotors J Hooked
Re annodised bells
Plated fittings
Here for sale some replacement discs for the B7 RS4 or any other vehicle which has the B7 RS4 discs fitted.
these are replacement Phaeton discs which have been professionally machined with a "J Hook" disc face, the depth of the milling has been programmed to coincide with the disc minimum thickness which in the case of these discs is 32.00mm and not 32.4mm as is the case with the drilled RS4 discs.
J Hook disc design is known to provide a better gas path, the design has been CNC'd as a harmonic curve.
The rotors due to design are now handed left and right unlike the OEM originals
So no cracked discs, no blocked drill holes leading to hot spots which cause pad transfer problems and pedal vibration which is fairly endemic on OEM Drilled RS4 discs
The rotors are brand new in their VAG boxes and packaging
The bells are OEM RS4 items from some removed discs which have been re annodised
For sale here at a very reasonable buy it now which doesn't cover the development and machining costs over the cost of the replacement rotors themselves.
this is a personal sale £450 inc postage (uk)
Re annodised bells
Plated fittings
