WANTED RS4 B7 AIRBAG FOR FLATBOTTOM STEERING WHEEL
Posted: Thu Dec 08, 2011 12:56 am
by BHP-MOTORS
REQUIRED ASAP, OR IF ANYONE CAN INDICATE TO ME OF ANY, HAVE LOOKED ON EBAY MOST ARE NOT FROM ENGLAND....
Re: WANTED RS4 B7 AIRBAG FOR FLATBOTTOM STEERING WHEEL
Posted: Thu Dec 08, 2011 3:35 pm
by DazN
Do you know the A8 airbag fit's the RS4 FBSW, it's exactly the same size and if you're using your existing wiring loom there is no difference at all.
They're a lot cheaper, no idea why!
Posted: Thu Dec 08, 2011 4:39 pm
by Revolution
I may be able to help you out......
I have an R8/Gallardo one lined up for our next project car with an airbag fitted - but were going to ditch it in favour of a plastic cover as were running a roll cage and harnesses.
how much do you want to offer...?
Glenn
Posted: Sat Dec 10, 2011 12:40 am
by BHP-MOTORS
DazN wrote:Do you know the A8 airbag fit's the RS4 FBSW, it's exactly the same size and if you're using your existing wiring loom there is no difference at all.
ther more square?? i need the round one?
Posted: Sat Dec 10, 2011 12:48 am
by BHP-MOTORS
BHP-MOTORS wrote:DazN wrote:Do you know the A8 airbag fit's the RS4 FBSW, it's exactly the same size and if you're using your existing wiring loom there is no difference at all.
my bad, i have just seen the round ones, are the part numbers same as the rs4 airbags? anyone else can back that up that the A8 airbag is the same?
Posted: Sat Dec 10, 2011 5:44 pm
by DazN
Trust me, the A8 airbag is EXACTLY the same, I've got one in mine! Part number is slightly different and the only thing you need to change is the wiring loom, but it's really obvious when you see it what needs to be changed. There are 2 spade plugs and sometimes they don't fit, 2 minutes to change them.
