Wanted - Any breakers out there - S4 B6 front ant roll bar
Posted: Sun Nov 06, 2016 3:14 pm
by wardy124
I'm looking for a front anti roll bar, 2003 B6 S4, are there any breakers about that can be recommended?
I've just had to change 2 front tires as the inner corners had lunched themselves, I had the drop links replaced by a garage in France who have managed to strip the threads in the end of one side of the sway bar and the drop link was not actually attached....
Any help is greatly appreciated!
Re: Wanted - Any breakers out there - S4 B6 front ant roll b
Posted: Sun Nov 06, 2016 3:31 pm
by mongo
sorry miss posted, i have sway bars from my rs4 b7 kicking about if they are of any use..
Posted: Sun Nov 06, 2016 3:35 pm
by Ian_C
Anti roll bar = sway bar (what the Americans normally call it!)
Posted: Sun Nov 06, 2016 3:38 pm
by marc1
ARB's and sway bars are the same thing.
All A4 / S4 / RS4 front Anti roll bars are the same aross the B6 / B7 (8E0) platform. So you'll be best going for an A4 one as there will be more and will be sold cheaper. Personally though, the S4 needs tightening up massively, so I'd get the thick H&R RS4 bars front and rear and run both in their stiffest settings. I'd also disconnect the variable power steering relay to give it some much needed weight and stop it going light mid corner.
Posted: Tue Nov 08, 2016 8:34 am
by wardy124
Thanks all,
I have the RS4 rear ARB which made a massive differednce to the handling
Unfortunately the front has stripped threads now in one end and is no longer bolted to the drop link.....
Mongo, I'll send you a PM.
