F/S c6 rs6 front callipers pads
Posted: Wed Jun 10, 2015 10:59 pm
by Rs6spec
V10 rs6 front brake callipers and pads. Removed from my c5 rs6 now going back to standard.
Pads pretty much new, covered 2000miles tops!
The callipers need a repaint. Pistons/ nipples/pins are perfect. In perfect working condition.
£680
Ed
Re: F/S c6 rs6 front callipers pads
Posted: Thu Jun 11, 2015 7:23 am
by jockthedog
Am new to the C5, so excuse my stupid questions :)
a) I have to assume that these are better than the stock C5 brakes, but how much better on a scale of 1 = same to 10 = twice as good.
b) Are they a bolt-on replacement?
c) what kinda pads?
d) Are the discs as new as the pads? If not, what thickness left?
e) Hoses required/included?
Posted: Thu Jun 11, 2015 11:04 am
by bam_bam
jockthedog wrote:Am new to the C5, so excuse my stupid questions :)
c) what kinda pads?
Bigger discs and larger sweep so better for repeated big stops, also cheaper pads (OEM are proper Brembo). Callipers bolt straight on, HOWEVER, using the C6 RS6 OEM discs will require a spacer behind the bell or hub, not the best thought making its way to the frontal lobe of your brain when you start really 'pushing on'.
The alternative is (as I and others have done) to get some custom bells made up and couple to AP/Alcon/whatever 390mm rotors. That way you end up with correct offset AND much better braking performance to the C6 OEM disc, the former will have miles better air-gap, vane counts and materials, they'll also be directional - the OEMs aren't, which boils my blood.
I can sell you a spacer kit for the C6 discs but I'd advise going for a custom disc setup.
Posted: Thu Jun 11, 2015 4:44 pm
by SuprSi
I went another route but it works out a hell of a lot more expensive than this and most likely isn't as good at stopping. The kit the op is selling is a bargain :D
Bams custom discs bump the price up a bit but would deffo be worth doing. That's the way I'd go if I was upgrading again. I bought bigger discs from the states that use the standard caliper, just spaced out a bit.
Posted: Tue Jul 07, 2015 2:17 pm
by Rs6spec
Bump
Posted: Mon Sep 14, 2015 10:29 pm
by Rs6spec
Bump
Posted: Tue Sep 15, 2015 12:57 pm
by Rs6spec
I might as well let the Discs I have go with these to, now included in price is a very decent pair of C6 front discs.
Discs pads and calipers.
I'll regret selling these.
Cheers all,
Ed
Posted: Sat Sep 19, 2015 4:43 pm
by bigben143
you have pm i will take these
Posted: Mon Sep 21, 2015 5:31 pm
by Rs6spec
Still here
Posted: Thu Oct 01, 2015 4:52 pm
by Oaks632
Just stumbled across this thread...........and appreciate it's a few weeks old now.
Interested to know if the C6 front pads and disks etc are still up for grabs as I could be interested, I'm due a change soon.
If so, I'll drop you a PM.
Oaks
Posted: Sat Oct 03, 2015 6:46 pm
by Rs6spec
Hi all,
These are still up for sale.
Discs have plenty of life, a easy 20k and pads have very little wear.
Pm me if interested
Based in Wimbledon.
Posted: Sat Oct 10, 2015 3:44 pm
by Frago
Hi, Do you still have the callipers ?
Gary.
Posted: Mon Oct 12, 2015 10:35 am
by Oaks632
Given there is some interest in the front calipers, would you consider selling the discs and pads separately ? :bigblink:
Have dropped you a PM
Posted: Sun Oct 18, 2015 7:47 pm
by Rs6spec
PM's sent
Back up for sale.
Lots of interest, but nothing definate.
Cheers.
