FS: NEW R8 front ceramics (RS4 B7 B8 RS5)
Posted: Sat Jun 07, 2014 1:05 pm
by C6NVS
I bought these new, with the view to getting into an R8.
Now ambition meets reality, and as the R8 won't be a feature, they are surplus.
NEW 2 x 380 x 38 disks (the new type of bell)
NEW 2 x front calipers
All items are completely blemish free, new and unused. Pad fitting kit included, but no pads or backplates.
Caliper carrier to retrofit other models RS4/RS5 can be supplied if required (maybe someone on here can supply?).
Disk part numbers: 420 615 302 G and 420 615 301 K
Disk manufacture date (stamped on both bells): 26/13
Caliper part number: 420 615 105 (other side caliper still boxed)
£3,450 ono
Please respond via PM.
Items are located in London
Re: FS: NEW R8 front ceramics (RS4 B7 B8 RS5)
Posted: Sat Jun 07, 2014 1:39 pm
by classba
Wow Bretto.... that's a bargain.
You might also want to post on r8talk as well.
GLWTS
Posted: Sat Jun 07, 2014 5:21 pm
by Ian_C
PM Surrey Sam, he is on the look out ceramics
Posted: Sat Jun 07, 2014 7:35 pm
by CellDamage
So much want
Posted: Sat Jun 07, 2014 8:07 pm
by el_ringo
Must resist....
Posted: Sun Jun 08, 2014 12:57 pm
by Surrey Sam
Ian_C - thanks for looking out :thumbs:
C6NVS - Interested to know how you think these would work on a B7 RS4?
As far as I understand you can't get the B7 mounting brackets separate from Audi and would therefor need custom ones made. The bell offset is also different and would require the disc to be spaced out by 5mm which then doesn't leave a lot of hub for the wheel to mount, you also have the centre bore of the bell being larger too. So basically custom brackets and bells to get them working safely - unless you know otherwise?
I think B8 RS4 & RS5 owners should not have as much trouble and just require calliper mounting brackets.
Posted: Sun Jun 08, 2014 4:07 pm
by C6NVS
I have no direct experience with fitting R8 disks to a B7, so can't confirm or deny what is required. All I know is that it has been done.
I do have access to an OEM B7 ceramic caliper carrier. B8 and RS5 carriers would have to be found.
Posted: Tue Jun 24, 2014 9:59 am
by C6NVS
Price reduced
Posted: Tue Jun 24, 2014 10:02 am
by qwick69
would these fit an RS6 C7 ?
Posted: Tue Jun 24, 2014 10:18 am
by C6NVS
Good question, I don't actually know, but I doubt they would without some significant modification.
Posted: Sun Sep 21, 2014 2:59 pm
by d4nxv
Are these still available and pics? Thanks
Posted: Wed Sep 24, 2014 9:27 am
by C6NVS
Now Sold
