FS: Brand New RS4 B7 Coilovers
Posted: Fri Nov 30, 2012 2:42 am
PRICE - £690 Including Shipping (They are being shipped from New Zealand which is where I currently reside)
Fixes all DRC issues.
Here is a link to their website - http://www.yellow-speed.com/dynamic-pro-sport.php
Spring Rates: 14kg front, 10kg rear
FEATURES
- 33 levels of adjustable damping
- Made from high quality 6061 aluminum with T6 for increased hardness
- Adjustable spring perch for height adjustment
- Adjustable body allowing maximum suspension travel
- Pillowball top mount with adjustable camber (not available for some models)
- Monotube high pressure design reduces oil leakage
- Electroplated body for protection from corrosion and rust
CONTENTS
- Set of four coilovers: front left, front right, rear left, and rear right
- Spanning adjustment wrenches
- Dampening adjustment keys
PRODUCT DESCRIPTION
The DPS coilover system is a 33 way damper and rebound adjustable monotube full coilover system. The setup has separate height and pre-load adjustments allowing for optimal adjustment and allowing full strut travel at all times. Pillowball upper mounts and top mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.The product details and specifications for this product provided in this listing is produced with the best of our ability. If you have any questions regarding this product, please send us a message prior to purchasing this item.
FEATURES
CONTENTS
PRODUCT DESCRIPTION
