I have a 2013 b8 rs4 engine breaking (code cfsa) 38k miles covered.
Oil pump has failed causing damage to crank. All parts available. Some items noted that are available:
*Sump casing
*Engine casings
*Rocker covers bank 1 and 2
*Cylinder heads (these can be sold as seen or reconditioned for an extra cost)
*Crank pulley
*Drive plate/ flywheel (auto)
*coil pack looms bank 1 and 2
*all sensors for engine
*inlet manifolds with fuel rails
*oil filter housing with cap
*complete engine loom
*Engine fuse box, relay box
*flow knock sensors with loom 4x
*pcv breather system with all pipes and breather box
*alloy coolant pipe (rare)
*water pump and drive shaft
*coolant hoses
*evap purge valves bank 1 and 2 plus sensors
*oil pick up pipe, lift pipe to oil pump
* bank 1 and 2 exhaust heat shields
*oil pump drive and gear
*injector loom 2x
*high pressure fuel pumps, roller followers 2x
*fuel injectors 8x
Drops an email if need anymore info or reply on this.
Stephen
Audi 2013 b8 4.2 v8 rs4 engine breaking
Re: Audi 2013 b8 4.2 v8 rs4 engine breaking
Email. Hallfm@hotmail.com
Last bumped by Audilove_a7 on Thu Sep 13, 2018 11:49 am.
