F/S B7 Space Saver Wheel
Had this as a spare for B7 RS4 instead of the puncture repair kit. Note fits on rear only
£80 posted
£80 posted
Re: B7 Space Saver Wheel
Need this gone
£50 posted or it gets binned at the weekend
is the centre the correct 57.1mm or 66.6mm?
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Bore looks to be about 68mm.
Part number is 8K0 601 027D if this helps.
Re: F/S B7 Space Saver Wheel
as long as the centre bore is same or bigger and pcd/offset is correct it wont matter for a spare-its only to limp you to a tyre Shop after all...
Correct Arthur and it does fit on the rear of a B7 - trust me
Hi Ian, would the posted price include Northern Ireland?
Yes that won't a problem - as long as it's less than £50 which I'm sure it will be
Sounds good, you have PM.
Users browsing this forum: No registered users and 65 guests
