Hi, TPS sent me the part number I ordered it was the wrong one when I checked on the back it was a different part number to the packaging I am still waiting for them to get another one in I did chase them two weeks back, will have another go at them Monday...gav525 wrote:Hi mate,Robnic wrote:Hi Faisal,
FYi the link you posted is what my plinth looks like, new and for sale if anyone wants it. The plinth you've pictured have you received it does it definately fit the RS4 grill or just an A4?
Rob
Did you ever price up one like Faisal's from TPS? I want the same one with the parking sensor holes but I'm struggling to find one online to order.
Failing that, is the one you have the same except minus the holes?
B7 RS4 US spec number plate plinth
- Robnic
Re: B7 RS4 US spec number plate plinth
B7 RS4 MTM K540 Sprint loon, Lysholm/Opcon twin-screw supercharger, Ceramics, HEL Hoses, Loba SM Fly, Sachs performance clutch kit, MTM full stainless exhaust system with freeflow cats & quad valved tailpipes, Hotchkis ARB's, Bilstein B16 Coil Overs, LED Rear lights, Interior & LED 50W DRL's, Buckets in race cloth, Black optics, FBSW, Titanium pack, Solar Sunroof, Adaptive lights, MTM 10mm spacers Fr & Rr, 193 Nav unit, 2nd careful owner
- Robnic
No joy with this yet TPS ordered a few different part numbers and none are the smooth type with PDC holes I've left the guy looking into it some more...
Rob
Rob
Were any of the incorrect ones that came by any chance the US-spec with sensor holes?
- Robnic
Hi,
The Stateside ones are smooth but they don't have front PDC so no holes, fecked if I know what part number to order to get a smooth with PDC tried the part number Faisal has a pic of even sent that pic to TPS it came but with different part number and no holes TPS re-ordered it incase it was packaged wrong and same one came again??
Obviously it is available but is taking some getting hold of!!
Rob
Rob
Rob. Do you remember what the price is for the none PDC version from TPS?Robnic wrote:Hi,
Rob
I want to use one to manufacture a tool to make a Carbon equivalent but obviously cut the holes in after cure.
- Robnic
Hi bud,
just under £60 but that was 2 years ago and I do get a bit of trade discount of around 10 - 15%. Part number looking back on our system is 8E0 807 287 C3F Z - but that doesn't look quite right probs one of the girls in reception typo'd sorry!
Just remember if you are making one the postion of the sensor is determined not by the plinth but the mounting in the grill behind the hole is just there for it to pass through sure you are aware just thought I'd mention it. My grill is carbon wrapped one of your plinths would suit mine
Rob
Rob
I'm tempted to buy a non PDC smooth plinth and drill my own holes, should be easy enough to get them in line with the sensors?
- Robnic
That was my thoughts but the smooth plinth has an upper and lower strip the upper strip overlaps where the hole needs to be.gav525 wrote:I'm tempted to buy a non PDC smooth plinth and drill my own holes, should be easy enough to get them in line with the sensors?
Robnic wrote:Hi bud,
Rob
Cheers for the info Rob
If I successfully get these underway I shall let you know. I will also have a good mooch around for the version with the holes and see if I can find anything
Users browsing this forum: No registered users and 26 guests
