Part Number: FDB4165
Brand: FERODO
Description: Brake Pad Set
Includes wear sensors.
Front Premier Brake Pad Set FDB4165
Ferodo Premier brake pads are the recommended option for Original Equipment (OE) replacement pads. Engineered with vehicle specific friction materials you get the best possible stopping power, extended service life and reduced noise.
Brake fade is minimised by using specially selected thermal underlay to reduce heat transfer the other brake components, including fluid. Ferodo brake pads come ready to perform out of the box without the need for extensive bedding in.
Contains: 1 Axle Set (4 Disc Brake Pads)
2005-2008 AUDI A4 RS4 Saloon
2005-2008 AUDI A4 RS4 Avant
2006-2009 AUDI A4 RS4 Convertible
£70 collected.
Can also be posted if required.
Front Ferodo Premier Brake Pads FDB4165
Re: Front Ferodo Premier Brake Pads FDB4165
£60 collected
