Having a clear out, and have my old rnse with a damaged/cracked screen from my old 2007 rs4. I damaged this loading wood between the seats.
Works totally fine, no issues just the cracked screen. Screen illuminates but the LCD has liquified, is the best way to describe it. Ideal for spare if you have a faulty volume button or lense. The screen is only held in with 3 screws.
I have a rnse in my c5 that is recently new so I don't need it.
Part number is 8H0 035 192 J
Looking for £220
F/S rnse 2007 rs4 £220 damaged screen
Re: F/S rnse 2007 rs4 £220 damaged screen
Do you happen know if this will fit in a 2004 B6 S4? I have RNSE installed but it won't read the Nav DVD currently and if these items were mechanically identical, installation of your unit after swapping in my screen might see me right.
thks
Steve
thks
Steve
That part number seems to be listed as a North American RNSE.......is there any difference in the operation or wiring from the Euro version?
Hi there,
It is from a uk rs4, so it should fit into a b6 with a rnse.I would imagine these are identical inside. The screens can be swapped quite easily with a small screwdriver set.
It's definitely a uk spec rnse. From my old rs4. I'll double check I've jotted down the correct part number.
Ed
Ed
Hi Ed,
Did you manage to check the part number?
Rgds
Steve
Rgds
Steve
