Rs4 B7 Black
Posted: Mon May 02, 2016 11:55 pm
Deleted the old thread so ill now try again without various people jumping in saying how its not worth it and I 've missed this and that . I 've not been around these cars long so not got to involved . All I have to go on is the paperwork and history I received with the car when I got it September 2014 .
I purchased the car as it was a car on the list that I wanted to own , but now it just sits in the garage doing nothing which isn't what these cars were designed for and id like to go back to a RWD turbo car as for me there more fun and more involved ( imo) And before I get slated again , YES the car has 110k on the clock!
Black Rs4
Early 06 Plate SO cheaper TAX .
History book is stamped as
14/08/07 - 2757 miles - Audi
28/11/2008 19926 miles - Audi
25/06/09 37938 miles - Audi
02/06/10 57425 miles -Autobahnsussex.com
28/09/11 Audi removed Tyre pressure valves . Exhaust tail pipe flaps stuck - replaced £1502.80
15/09/11 71432 miles - Auto store specialist cars -Service +New front discs and pads + new locking wheel nuts
28/09/11 71844 miles - Audi Carried out ignition coil product enhancement 28E9 and replaced oil feed pipes enhancement 17D7
12/01/13 88229 miles Auto store specialist cars
22/02/13 Auto store - New under trays fitted £144.15
13/09/13 Auto store - Remove front bumper replace headlight bulbs Philips D1S £252.
03/05/14 Auto store -
Remove fuel distribution unit
Remove throttle body and inlet manifold
Replace inlet manifold valve actuator £279.96 , Oil separator vacuum solenoid valve unit price £111.97
Bleed cooling system + service
14/05/14 Auto store - Replace auxiliary belt + tensioner £169.36
29/04/14 101614 miles Auto store specialist cars
10/09/2014 102,362 Auto store specialist cars ( Prior to sale ) Along with rocker cover remover and knock sensor replaced .
It is now due a service as it is displayed on the dash screen , im more than happy to get this done back at auto store prior to sale or you can do it yourself .
I've recently had all 4 wheels painted along with 4 new tyre's
Front + rear pads changed
New front screen + wipers
Pipercross panel filter fitted
Complete front arm kit fitted , upper + lower along with drop links and track rod ends
N/S Front driveshaft gator replaced (Audi part)
Then had 4 wheel hunter alignment
MOT due September
Other than this I've not needed to do anything .
Black front grill
Black window surrounds
Black exhaust tips
Piano black interior trim with black headlining
Side airbags , passenger / drivers airbags
Sat Nav/tv with disc changer in glove box and twin SD card slots , Navigation plus (RNS-E) Don't mean a lot to me!!
Heated / electric front seats + heated rears
Centre arm rest with phone socket inside ( I've never used this ) NO nasty holes on the dash for a phone holder .
Not sure if its an extra, all the door handles light up very faint red . Nice touch .
Auto dimming rear view mirror
Dual climate control
Bi xenon Headlights - Auto plus coming home lights and DRL
Bad points , its 10 years old
Small crack under the drivers side mirror casing . Some nice guy decided to hit it and not stop !! But mirror still works fine and you can only noticed it when sitting in the car
Stone chips to front bumper + bonnet
I've been as honest as I can . It drives as it should it has good history and its also HPI clear .
Before the 100k mile haters come along ,please keep your negative opinions to yourself ,if you don't think its worth it then don't buy it . I' m not in need of the money so no real hurry if it goes it goes . And yes I got a bit lucky when buying this car ,I was in the right place at the right time as the old owner needed money asap as he was moving abroad ! (As per Sam's comment ) Hope that clears things up a little .
£15,250
Black Rs4
MOT due September
Black front grill
Black exhaust tips
£15,250
