Audi RS4 Avant B7 - JamesBaby's
JamesBaby
Post by JamesBaby » Wed Nov 13, 2024 3:00 pm
I’m thinking of selling my pride & joy. Not in any rush as the car needs someone who is equally enthusiastic about the B7 RS4, to really appreciate it. This is an OCD owner car and I have an online blog on RS246.com detailing my journey with it under “JamesBaby’s RS4 B7 Daytona & Avant”
RS4 B7 Avant in Phantom Black. Registered Dec 2006.
Spec:
- Bucket Seats from factory inc Flat Bottomed Steering Wheel
- Carbon Inlays
- Front & Rear Heated Seats
- Factory Bose upgraded to Pioneer with CarPlay\Bluetooth\DAB\USB
- Reversing Camera
- Auto Lights\Wipers\Dimming Rear View Mirror\Coming Home Light Function
- Adaptive Turning Xenon Lights with DRL’s
- Cruise Control
- Privacy Tinted Glass
- Armrest
- Fridge in Glovebox
- Rear blinds
- Homelink Garage Door Opener
- DRC SS+ Suspension with KW Height Adjustable Springs
- Zinram Sports Cats, ECS H Pipe, OEM back boxes with fully working valves.
- BMC Panel Filter
- OEM style RS4 mats
- EM Tuning Interior LED pack & EM Tuning LED DRL V2’s.
- Osram Nightbreaker Xenon lamps, and New Fog Light bulbs.
- ECS Tuning Short Shifter
- 10mm Spacers and rolled arch lips
- Maxton Design Kit
The car has gone through a full systematic OCD refurb and preventative maintenance program which is detailed in my thread.
Still on DRC suspension fully refurbished and overhauled. I also have an additional full set of DRC Shocks, flexi’s & DRC Valves should they be needed in future. Along with a DRC filling machine.
- Custom manufactured stainless steel DRC hard pipes installed.
- All shock absorbers and flexi hoses replaced. Upgraded with SS+ option DRC shocks (10mm lower from factory).
- Subtle lowering on KW Height Adjustable Spring kit. Lovely comfortable drive, yet totally planted on bends and spirited driving.
Full underside overhaul.
- All suspension arms and bushes replaced front & rear, inc. drop links
- All Top Mounts and all ARB bushes replaced
- Both front driveshafts and inner and outer CV joints and boots replaced
- Inner and outer track rods replaced.
- Wheel bearings replaced
- No rust underneath the car.
- All undertrays and covers present.
Replaced New as preventative maintenance:
- Aux radiators
- Oil Cooler Lines
- All injectors fully refurbed and flow matched
- All 8 Ignition Coils
- Both High Pressure Fuel Pumps and Cam Followers
- Engine Water Pump
- OEM Clutch Kit\Flywheel\Slave Cylinder
- Battery
- Rear Wiper Motor
- Wiper Washer Fluid Pumps
- Rear Boot Struts
- Coolant Temp sensor
- Camshaft Sensors
- Crank Sensor
- Intake Flap Sensors, both
- All 4 Knock Sensors
- MAF Sensor
- All O2 Lambda Sensors
- Reverse Light Switch
- New Genuine Windscreen
- New side indicator lamps
- New PCV Valve
- New PCV breather Hard Pipe
- New High Level Brake Light
- Still to fit sat in a box – New Aux drive belt, new Tensioner and new Pulley and other parts.
Other work done:
- Yearly Carbon Clean
- All vacuum system one way valves and Solenoids replaced
- Intake Manifold refurbished. Flaps and plugs reinstalled with high strength Loctite on screws.
- 034 Billet Intake Manifold Flap arms
Full brake system overhaul. Braking is very sharp and bites hard with little effort:
- Front Calipers refurbished in Brembo Red and Audi Sport Decal
- Rear Calipers refurbished and painted Brembo red
- Goodridge Stainless Brake Hoses
- New Discs and DS2500 Pads all round
- New Suction Jet Pump (which aids braking effect)
- New Titanium bleed nipples all round
- Motul RBF Brake Fluid
Service History:
The car has a Full Documented service history. With receipts, not just stamps in a book. With Audi up to around 80k, then with very good VAG specialists like Fontain and CM Tuning since then. For my 58k miles I have serviced it every 6000 miles.
All fluids have been changed regularly during its lifetime. Twice in last 3 years alone the Gearbox, rear Diff, & Power Steering. Coolant flush was done when new Water Pump was installed.
Will come with full MOT and oil change.
Overall condition:
The car runs and pulls like a train. The performance with the MRC Stage 2 map is truly astonishing, and the subtle exhaust upgrades but with OEM rear valved boxes makes a lovely but gentlemanly sound. The car has done 145k miles of which around 58k were done in the last three years with my motorway and European trips. The car does smoke a little at times but only in stop\start traffic. Never on cold startup or cruising or blasting hard. I know these cars do tend to use a bit of oil. After a recent engine flush and piston soak and changing to a good 5w40 it is much better. I’d say a litre every 1000-1500 miles.
I regularly see 29.3 mpg on a motorway run at 70mph. The car drives smoothly with zero squeaks, ticks or rattles.
The interior looks like a 30k miles car. The factory heated bucket seats are in excellent condition and the plastics\dash look amazing. I’ve seen a lot of these cars and some of the interiors are awful. This car shocks people when they first sit in it. The car has the black roof lining and rare factory black optics externally (not chrome that has been wrapped black).
The bodywork is stunning and regularly maintained and polished. It turns heads all the time. Looking closely the front bumper has some stone chips. Front wing has a tiny dent if you look for it, dent man could probably get rid. The car has the Maxton Design subtle skirts and splitter and it really sets it off. One wing mirror has a small scratch, but the bases are mint condition and no rusting etc.
The wheels were fully stripped and refurbished just over a year ago but I have managed to mark 2 of them if you look for it. The car has Michelin PS5’s all round.
The comfort and planted nature of the car cannot be understated. A lot of cars have gone down the coilovers route which we all understand. I’ve sat in both types back-to-back and make no mistake there is no contest to the original DRC. I also have a portable DRC filling machine and a full set of extra SS+ DRC shocks\flexis and new rear DRC Valves ready if ever required.
Short of a full colour-change re-spray or installation of a supercharger I don’t really know what else I can do on the car.
If someone is interested in a car like this then get in touch with an offer. I’m not wanting £20k for it but also don’t have time for Trade or silly offers.
Tel: 07921 827 896
laurat
Re: Audi RS4 Avant B7 - JamesBaby's
Post by laurat » Sat Nov 23, 2024 7:27 am
Comprehensive work includes wheel bearings (all replaced), suspension arms, drop links, CV joints/boots, DRC shocks, and much more (detailed in the blog).
Full brake, cooling, ignition, and sensor system refresh. It's a nice car, and good luck!
JamesBaby
Post by JamesBaby » Wed Nov 27, 2024 3:03 pm
Car now has MOT to 19th dec 2025 next year, and just had an oil\filter change.
Car also has additional security installed, forgot to mention.
JamesBaby
SOLD: Audi RS4 Avant B7 - JamesBaby's
Post by JamesBaby » Wed Dec 11, 2024 3:05 pm
CAR is now SOLD
