Dimensions RS4 B8 v B7
Posted: Tue Jul 03, 2012 5:31 pm
by Andyuk911
I had a look at the changes ...
B7
Length 4586
wheel base 2651
nose to centre of front wheels 934( so the B8 has less weight forward of the wheels))
B8
See pix and ... :-
Length: 4719mm
Height: 1416mm
Wheelbase: 2813mm
Width: 1850mm (without mirrors)
Luggage capacity: 490 litres (rear seats up), 1430 (rear seats folded down)
Unladen weight: 1795kg
Engine oil capacity: 10.7 litres
Fuel tank: 61 litres
Turning circle: 11.9 metres
Re: Dimensions RS4 B8 v B7
Posted: Tue Jul 03, 2012 5:46 pm
by stu
I had a B8 TDI Avant for two weeks and to me it felt even bigger than the numbers state, particularly forward of the driver.
Posted: Tue Jul 03, 2012 9:24 pm
by Nickyboy
Odd my B8 S4 felt smaller than my octavia VRS but is actually bigger.
Posted: Thu Jul 05, 2012 6:53 am
by Condor24
The length of the B8 is now marginally less than the C5 RS6, although the wheelbase of the B8 is greater than the C5.
Verification would be appreciated in case I am using the wrong measurements.
Posted: Thu Jul 05, 2012 7:38 am
by Brooner
Feck that could be tight to fit my garage as builder thease days give you the smallest garage thaey can get away with my B7 just fits with enough room to squeese out of the car when it in
Posted: Thu Jul 05, 2012 8:35 am
by P_G
Same with me but length wise. With the front touching the padded wall I have 15cm clearance between the rear of my B7 and the garage door when shut and that is 13cm longer. Squeeze!
R8 it is then....
Posted: Thu Jul 05, 2012 10:51 am
by Brooner
P_G wrote:Same with me but length wise. With the front touching the padded wall I have 15cm clearance between the rear of my B7 and the garage door when shut and thaat is 13cm longer. Squeeze!
R8 it is then....
Sounds like a sencible option
Posted: Thu Jul 05, 2012 7:25 pm
by adsgreen
Not so sure that the distance from the front wheels will make that much difference. Depends on whats there but from memory the B7 has alot of "styling" with not much substance. Wouldn't take a huge amount of frnt end redesign to change that without affecting the front end weight.
