Audi RS4 Dynamic steering options??
Posted: Thu Feb 15, 2024 8:36 am
by boba fett
Can you map out or change the settings (other than the obvious MMI settings) on the Dynamic steering? even in individual it still does it?
One thing I can't stand is how the steering weights up all the time, You pull out with nice light steering, then its weights up, so you go into the next fast roundabout with heavy steering, which in turn makes the car feel lethargic and a heffa!! it really spoils the drive for me, there is no need for it.
Re: Audi RS4 Dynamic steering options??
Posted: Thu Feb 15, 2024 10:21 am
by AndyBrad
just set it to comfort ?
Posted: Thu Feb 15, 2024 6:38 pm
by boba fett
As I have already said it still weights up!
Posted: Fri Feb 16, 2024 10:01 am
by AndyBrad
how strange. mine doesnt.
Posted: Fri Feb 16, 2024 5:44 pm
by boba fett
If your steering does not weight up after accelerating away, I can only assume you do not have the dynamic steering option?
Posted: Sat Feb 17, 2024 12:08 am
by Harry76
Yeah that should only happen in dynamic steering setting. I comfort it’s light all the time (which I find a bit too light)
Posted: Sat Feb 17, 2024 10:10 am
by boba fett
So let me get this right, in comfort when you go through fast bends your steering stays as light as when pulling out of a junction or when parking?
Posted: Sun Feb 18, 2024 5:40 pm
by Harry76
That’s correct , in comfort it stays light all the time
Posted: Sun Feb 18, 2024 5:52 pm
by boba fett
Ive just found this..
Every Audi with Drive Select has the steering option in Individual mode, however, there are two types of steering systems. QZ7 is the standard power steering and 1N8 is the optional Dynamic Steering, part of the Driver Assist Package.
Depending on which steering rack/system you have the option in Individual mode is either Dynamic steering or just Steering. Both have Comfort, Auto and Dynamic modes, but the Dynamic steering in addition to the steering torque also changes the steering ratios based on the speed and the Drive Select setting.
And you have the dynamic steering option? if so thats strange because mine still heavies up the faster I go even in comfort, and looking at information on it, its supposed to!
Posted: Sun Feb 18, 2024 7:55 pm
by stuartbarriskell
And not forgetting a replacement rack with Dynamic will cost you 3500 supplied and fitted ! As I know only too well
Sent from my SM-S918B using Tapatalk
