2014 sat nav update
Posted: Sun Jul 14, 2019 1:30 pm
by Rusty Racer
So after driving across grass fields again I figured it was time for an update and duly purchased the 2019 map via a mate in TPS.
Got home, found the MMI setup menu and selected update but after numerous attempts the sd card can’t be found?
It’s looking like I now require a firmware update also as it may be the original in the car still. Has anyone else come across this, I would appreciate a recommendation for a company who knows what they are doing :D
Re: 2014 sat nav update
Posted: Tue Dec 24, 2019 10:35 pm
by Rusty Racer
Ended up with wrong map so after getting the right one it’s all sorted FYI
Posted: Fri Dec 27, 2019 6:17 pm
by Flighty
How much was the SD? I have been trying to do this for some time....
Posted: Fri Dec 27, 2019 9:44 pm
by Rusty Racer
Just over a couple of hundred iirc. Most important thing is to get your current nav details off the car and then get the correct map 😁
Posted: Wed Jan 01, 2020 9:05 am
by Scub37
Where did you get the SD card from, Audi are quoting be over £300 to update the sat nav
Posted: Wed Jan 01, 2020 10:37 pm
by Rusty Racer
TPS but unsure of their current retailing policy (they might not be willing to sell to you).
Tbh it was a massive pita and I ended up back at the dealer after I had eaten a big slice of humble pie!
If you go to the dealer they should also update the firmware version and now I guess you get a 2020 map
Posted: Thu Jan 09, 2020 2:59 pm
by Ralpharr2001
I upgraded my firmware and maps in November using these guys with no problems:
https://upgrademyaudi.net/tutorials/upd ... -firmware/
Sensible money for the upgrade. If you follow their guide to the letter works a treat. Did take an hour or two to upload into the MMI. Adam is very helpful if you get stuck.
