Page 1 of 2
Exhaust rattle on cold start
Posted: Fri Oct 16, 2015 8:36 am
by S4WON
Hard to describe the noise, but its like a tin rattle from exhausts on cold start.
Only lasts bout 30 sec then clears. Doesnt do it on warm. Ive found a few threads about it, some say thats just the way it is, some say they had bits changed.
Anyone had personal experience?
Is a 14 car with 9k
Cheers!
Re: Exhaust rattle on cold start
Posted: Fri Oct 16, 2015 8:49 am
by Brooner
mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
Posted: Fri Oct 16, 2015 10:36 am
by carsarecool
Brooner wrote:mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
Mine's the same...
Posted: Fri Oct 16, 2015 12:12 pm
by marc1
Probably the exhaust valve flap. Get your ear close and see if it's present on one side or both. Apply something like WD40 (or better alternatives) to the valve after you've checked and see if it still happens the next day. If it's gone away, then you know the cause. If you have warranty still, then you'll be able to get the dealer to resolve (or supplier if it's an aftermarket product).
Posted: Fri Oct 16, 2015 12:31 pm
by S4WON
Thanks gents. Still have warranty and first service due, will get it sorted then
Posted: Fri Oct 16, 2015 12:58 pm
by RossDagley
Likely passenger side back box heat shield. Known to rattle.
Posted: Fri Oct 16, 2015 1:02 pm
by marc1
Yeah, that too and easier fix!
by Brooner
any fix?
Posted: Fri Oct 16, 2015 1:18 pm
by marc1
To the heatsheild?
Posted: Fri Oct 16, 2015 1:23 pm
by RossDagley
Brooner wrote:any fix?
Heatshield just needs bending differently normally - mine was rattling against the underside of the boot floor.
Might be as simple as a stone between the heatshield and the body of the car. Had a few of those also.
Posted: Fri Oct 16, 2015 1:47 pm
by Brooner
thanks will check it out see if it is this
Posted: Fri Oct 16, 2015 5:18 pm
by rspj
Mine do also it. Goes after minute or so and all ok after big rush of air on start up its on most audi
Posted: Sat Oct 17, 2015 6:46 pm
by Rallyz
As I understand it, the start up rattle is pretty normal, it's to do the emission regs. My 2012 one does the same.
Posted: Sat Oct 17, 2015 8:15 pm
by marc1
Depends what's rattling, surely?
Posted: Sat Oct 17, 2015 8:48 pm
by S4WON
I have no idea what it is, is booked in on the 27th, will let u guys know what they say mine was
