Jacking points
Posted: Sun Feb 15, 2015 10:46 am
by Brooner
Anyone got and pictures of the jacking points for a trolley jack as I'm going to put my spacers on the car
I've had a trawl thought he net but not found any thing yet
cheers
Re: Jacking points
Posted: Sun Feb 15, 2015 6:46 pm
by Brooner
i used the car jack but would still like to know the correct placement for the trolley jack if anyone knows
Re: Jacking points
Posted: Sun Feb 15, 2015 7:23 pm
by Surrey Sam
Don't know the answer but could you not use one of these?
http://www.ebay.co.uk/itm/Rubber-pad-ru ... 418fecd2a8
Re: Jacking points
Posted: Mon Feb 16, 2015 8:39 am
by Brooner
cheers will get one
Re: Jacking points
Posted: Mon Feb 23, 2015 5:50 am
by nwk00
In case you are still looking for it, and for other members' future reference.
Re: Jacking points
Posted: Mon Feb 23, 2015 5:51 am
by nwk00
Which wheel do you have on and what spacer size are you getting?
Re: Jacking points
Posted: Mon Feb 23, 2015 7:41 am
by Brooner
I have rotors and 10 mm spacers
Re: Jacking points
Posted: Mon Feb 23, 2015 8:37 am
by Graeme4130
I use the metal seam inside of each wheel as per the diagram a couple of posts up
Re: Jacking points
Posted: Tue Feb 24, 2015 1:46 pm
by Pando99
I used the points as mentioned above with no problems. I did make a tool the same as the rubber one out of wood
I did contact the guy on Ebay as it doesn't mention RS4 fitment and got no answer, however i think you would need a slot of approx 12mm wide by 20mm deep and 110 long maximum if i remember correctly. If you trawl through all the different ads it does tell you the slot sizes
I was going to machine one at work but couldn't find a suitable material
Booner - if you do get round to sussing it order one for me as well and i'll sort you out back in the Ury
Re: Jacking points
Posted: Tue Feb 24, 2015 4:46 pm
by Brooner
Pando
will see how the fitment is and let you know
Re: Jacking points
Posted: Tue Feb 24, 2015 4:53 pm
by MK2Golf24v
It doesn't fit.
Better off with attic sheet if neoprene on the jack pad.
Re: Jacking points
Posted: Tue Feb 24, 2015 4:59 pm
by Brooner
you tried these andy?
Re: Jacking points
Posted: Tue Feb 24, 2015 5:22 pm
by MK2Golf24v
Aye I've got a couple. The slot is too narrow. I just use them on axle stands on my MK2 golds.
If you have a low profile jack some neoprene or heavy rubber sheet is best really.
Re: Jacking points
Posted: Tue Feb 24, 2015 6:04 pm
by Brooner
Cheers it's ordered now so will ser if I can modify it if need be
