Eibach spacers
Posted: Thu Nov 06, 2014 5:46 pm
by lem
Car is booked in for a full Milltek in a week and am considering spacers at the same time to get everything done at once....
The workshop I'm using currently only stocks Eibach spacers and will let me know on the day what width they recommend.
Any experience/thoughts on Eibach as I know many of you have gone for the H&R ones
Thanks all
Re: Eibach spacers
Posted: Thu Nov 06, 2014 6:37 pm
by blueaudi
I'm no expert but I think the key is to make sure that the spacers are hub centric, that's the first question to ask the supplier.
Re: Eibach spacers
Posted: Thu Nov 06, 2014 8:51 pm
by RIV
I would just play safe and use H&R's you can get them from virdee
Site
Sponsor
Re: Eibach spacers
Posted: Thu Nov 06, 2014 9:10 pm
by BMW2RS4
I've used both H&R and Eibach spacers in the past and have found little to no difference in quality between them; they are both excellent.
Re: Eibach spacers
Posted: Fri Nov 07, 2014 12:36 pm
by carsarecool
10mm works well.
Re: Eibach spacers
Posted: Fri Nov 07, 2014 3:51 pm
by lem
Great - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
Re: Eibach spacers
Posted: Fri Nov 07, 2014 3:52 pm
by lem
Oh and if not then Ill go with Riv's suggestion and contact virdee
Re: Eibach spacers
Posted: Fri Nov 07, 2014 4:28 pm
by RIV
I would go 10mm
Works perfectly!!
Re: Eibach spacers
Posted: Fri Nov 07, 2014 7:02 pm
by carsarecool
RIV wrote:Great - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
I would go 10mm
Works perfectly!!
+1
Re: Eibach spacers
Posted: Fri Nov 07, 2014 7:55 pm
by blueaudi
You may find that 10mm is the minimum, otherwise they may not be hub centric (which is a must). Speak to Virdee, he knows his stuff but can be slow to respond.
Re: Eibach spacers
Posted: Fri Nov 07, 2014 8:00 pm
by RIV
This!!....Must be hub centric or you will suffer wheel wobble
Re: Eibach spacers
Posted: Fri Nov 07, 2014 8:35 pm
by MK2Golf24v
RIV wrote:You may find that 10mm is the minimum, otherwise they may not be hub centric (which is a must). Speak to Virdee, he knows his stuff but can be slow to respond.
Total pish
Re: Eibach spacers
Posted: Fri Nov 07, 2014 8:41 pm
by smudge
carsarecool wrote:RIV wrote:Great - Ill see what they have in stock. Think they do a 3mm, 5mm, 8mm etc so maybe the 8mm will be a good compromise?
I would go 10mm
Works perfectly!!
+1
+2.
