Page 1 of 2
Dyno figures
Posted: Tue Aug 26, 2014 1:47 am
by smudge
Ok, so on Sunday I was up north & popped into an open day being held at Shark Performance. They have a 4wd rr, so for £60 (all of which went to charity) so I got the RS dyno'd.
Anyway, point of my post / the thread.... If you've had your car dyno'd, place the details on here to see how we're all doing....
I wasn't particularly enamoured with mine, but then I wasn't surprised either.
409.6bhp was the result. I do have a full chart plotting all the figures, so I'll load that on here tomorrow.
Al.
Re: Dyno figures
Posted: Tue Aug 26, 2014 6:50 am
by Graeme4130
Mine made 444bhp at the rs246 RR day at AMD Essex last year
Re: Dyno figures
Posted: Tue Aug 26, 2014 7:36 am
by tee-bee
Haldex on or off?
Re: Dyno figures
Posted: Tue Aug 26, 2014 7:52 am
by Graeme4130
tee-bee wrote:Haldex on or off?
Good question, don't know
Re: Dyno figures
Posted: Tue Aug 26, 2014 8:02 am
by doodlebug
Haldex?!
Re: Dyno figures
Posted: Tue Aug 26, 2014 8:11 am
by nwk00
Here you go
Re: Dyno figures
Posted: Tue Aug 26, 2014 10:06 am
by Surrey Sam
It's still mechanical on the RS4, so no Haldex system.
Re: Dyno figures
Posted: Tue Aug 26, 2014 10:30 am
by HYFR
RS 5 MRC Dyno 432PS
Re: Dyno figures
Posted: Tue Aug 26, 2014 3:54 pm
by moonigan
smudge wrote:Ok, so on Sunday I was up north & popped into an open day being held at Shark Performance. They have a 4wd rr, so for £60 (all of which went to charity) so I got the RS dyno'd.
Al.
I'm guessing this was at the wheels and not the flywheel which would account for the 10% loss.
P
Re: Dyno figures
Posted: Tue Aug 26, 2014 5:00 pm
by GrahamS4
Doesn't the graph say 443hp?
Re: Dyno figures
Posted: Tue Aug 26, 2014 5:09 pm
by lengster1
I'd like to bet that the b8 suffers pretty much the same drop in bhp as the cars get some miles under their belt.
Re: Dyno figures
Posted: Fri Sep 05, 2014 2:54 pm
by s4tokyo
I have nothing to contribute in terms of explanation, just adding more questions. That said, APR - reputable as they are - show same power figure as Audi quoted figure (on 93 Octane).
So how, in simple terms, how can there be so much variation in different owner figures - the lower figures I mean? …Environment temp and atmospheric pressure conditions?, engine build variation?, engine mileage / carbon deposit?, dyne maker / calibration?, other?
General consensus is that it’s lower for the RS4 than advertised by Audi??
http://www.goapr.com/products/ecu_upgra ... i_rs5.html
Re: Dyno figures
Posted: Fri Sep 05, 2014 5:02 pm
by adsgreen
it's very easy to change the data by something very trivial.
the choice of tyre, it's wear and even pressure can really upset a dyno.
the wear n tear will impact things - you will get slightly different results to a car that's spent 10k on a motorway to 10k driving around town.
Another "trick" some unscrupulous tuners use is to simply reset the ecu and wipe out the long term fuel trim adaptions. This generally puts the car on a much more aggressive setting and it then backs off depending on the fuel being used.
The only accurate way to do it is to take the engine out and bench test it.
Re: Dyno figures
Posted: Fri Sep 05, 2014 11:06 pm
by s4tokyo
Thx. Had not read that before - tire condition, past engine usage style, …. interesting.
Curious also, but although fuel octane level are supposed to be according to global rating / standards, is it accepted that (high octane) fuels vary slightly from brand to brand, country to country …and so possibly ‘also’ this impact ‘a little’ on engine performance?
That being said, unlike the supercharged 3.0litre on B8 S4 which typically dyno’s at higher values than quoted by OEM, there’s no chance of that on the RS4, right?:-) From various reports / posts shared it seems to dyne at lower values than quoted by OEM - not a big deal, but does irks a little when you find something is ‘not exactly as advertised’
Re: Dyno figures
Posted: Fri Sep 05, 2014 11:11 pm
by Graeme4130
It's also worth noting that different RR operators will have different assumptions for drivetrain loss between wheels and fly
Only way to gauge improvement consistently is to use the same rr and calculation methods
