Shortened number plate holder
Posted: Fri Apr 11, 2014 11:06 am
by cmcm3
I have a 6-digit plate I'm planning to put on the rs4 when it arrives and like a short plate to minimise the amount of unoccupied white space. Has anyone shortened the front plate holder or is a shortened plate holder available from anywhere?
Thanks in advance!
Re: Shortened number plate holder
Posted: Fri Apr 11, 2014 11:10 am
by C17LJR
You'll be able to buy a us or jap spec plate holder from audi or tps, alternatively you could cut a section out of a standard holder and plastic weld it back together then refinish it
Posted: Fri Apr 11, 2014 12:27 pm
by cmcm3
Smart thinking. Will need to find a plastic welding expert.
Posted: Fri Apr 11, 2014 2:11 pm
by smudge
cmcm3 wrote:I have a 6-digit plate I'm planning to put on the rs4 when it arrives and like a short plate to minimise the amount of unoccupied white space. Has anyone shortened the front plate holder or is a shortened plate holder available from anywhere?
Thanks in advance!
Speak to your dealers parts department, there are a couple of sizes available for the plate holder. I know as I've asked the very same question.
Posted: Fri Apr 11, 2014 9:04 pm
by RS6chris!
C17LJR wrote:You'll be able to buy a us or jap spec plate holder from audi or tps, alternatively you could cut a section out of a standard holder and plastic weld it back together then refinish it
That is what I did...cut out middle section etc..
Worked a treat.
Posted: Sat Apr 12, 2014 10:46 am
by carsarecool
Any pics?
Posted: Sun Apr 13, 2014 11:45 am
by RS6chris!
Posted: Sun Apr 13, 2014 5:59 pm
by S5 tony
Only thing I would off done different is screw the plate holder on then stuck the number plate on with double sided tape I just don't like the screw caps
Posted: Sat May 03, 2014 2:42 am
by Astonished
RS6chris! wrote:....
I've got short plates too, that I will be transferring across when the new RS4 arrives, so will look at same options.
This looks like a good solution.
Does anyone have any pics of the rear of the plate holder and the grille and the fixings between the two?
Thanks heaps
