Afternoon all,
The dreaded DRC decided to poo it's pants a couple of weeks ago! Front shocks were weeping and one of the flexis to the front. Given the car is getting on for 10 years old now, I decided against replacing with a new DRC shock as I'll just end up chasing all the pipes and shocks eventually every couple of months, along with the costs of getting a re-charge of the system every time!
Having looked at the various options I originally had my heart set on a set of B16 Bilsteins as I liked how easy they are to adjust the damping, they are also on offer down to just over £1500 at Demon Tweeks. The only problem being there is a huge lead time at the moment, nobody has stock until end of March and I couldn't drive any longer with the car handling how it was.
The other option I'd looked at was the Koni setup from CRS Performance, these were in stock so it was a no brainer.
All fitted last night and so far absolutely brilliant.
Handling feels very similar to Dynamic in terms of how flat and stiff it is through a corner, but the composure over bumps/potholes/drain covers is 10x better, it felt very crashy before if I went over the same drain cover in Dynamic. The only difference I would say in the handling compared to Dynamic is the front end is a little less pointy, I have an S4 rear antiroll bar (21.7mm instead of the RS4's 16mm) on the way from ebay to solve this.
I'm booked in for 4 wheel alignment in a couple of weeks so I'll update if anything changes after that.
And just as a disclaimer, Steve from CRS isn't aware I'm posting this. I'll be honest I had my doubts, a lot of Steve's posts (no offence if you read this Steve!) come across as a sales pitch (hence wanting the B16 kit originally), I wasn't expecting the Koni setup to perform better than the stock setup but I've been pleasantly surprised!
For anyone that's on the fence about what kit to go for I'd 100% recommend the Koni kit moving forward!
DRC Delete - Koni/CRS Performance Review
Re: DRC Delete - Koni/CRS Performance Review
Nice review and glad to hear there are some alternatives. I'm still rocking the DRC but the day may come when it'll need replaced - will bear this in mind.
Thanks for the review.
Is this on original springs or the H&R they offer?
MY15 RS4 Avant
I've used the original springs as I wanted to retain the original ride height.
Great review mate! How do you find the Konis on longer drives, and did they change the ride height much?
Users browsing this forum: CusterDome and 47 guests
