Radiator fan cooling
4.2 V8 32v FSI - 444 bhp
Kees777
Post by Kees777 » Mon Dec 25, 2023 7:35 pm
Hi all,
Question I have is as from which oil (or water?) temperature the radiator fan should still be working even after shutting down the engine?
In the past I noticed that the fan would at times continue to run after stopping the engine but now it does not. The front sides (wheel fenders) get quite warm as well when parked, as observed near to the side radiators I believe.
Many thanks
Rs4nutter
Re: Radiator fan cooling
Post by Rs4nutter » Tue Dec 26, 2023 11:27 am
@Kees777 have a similar problem, well one of the problems, car is booked in on Friday with Audi, so may be a similar fault but will let you know what I get told. My osf gets alot of heat come through, maybe just the way fan blows hot air out!!
Kees777
Post by Kees777 » Tue Dec 26, 2023 7:55 pm
Thanks, will do the same, next week Tuesday to Audi. Will advise
Rs4nutter
Post by Rs4nutter » Fri Dec 29, 2023 4:37 pm
@Kees777, car in today, check post Coolant for Audi's answer to my problem.
Hope its same as yours answer
