Hi Guys,
Can anyone point me in the right direction to fix these problems please?
Thursday,29,December,2022,09:49:48:57579
VCDS Version: Release 22.10.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 01: Engine Labels: 079-907-560-CFS2.clb
Control Module Part Number: 8T2 907 560 E HW: 8T1 907 560
Component and/or Version: 4.2l V8HDZ / H04 0003
Software Coding: 1225003225A6000A2000
Work Shop Code: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002 (AU48)
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E73F981A1975E7DB0-806A
7 Faults Found:
8113 - Performance Malfunction in Cooling System
P2181 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 76238 km
Date: 2022.10.30
Time: 17:24:00
Engine RPM: 2385.00 /min
Normed load value: 24.7 %
Vehicle speed: 57 km/h
Coolant temperature: 66 °C
Intake air temperature: 29 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.182 V
Unlearning counter according OBD: 40
CAN status - engine control module-Bits 0-7: 0
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 4
Cruise control switch actuation-Bits 0-7: 0
16811 - Fuel Trim; Bank 1
P0171 00 [096] - System Too Lean
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77886 km
Date: 2022.12.03
Time: 10:55:40
Engine RPM: 1975.50 /min
Normed load value: 47.5 %
Vehicle speed: 64 km/h
Coolant temperature: 78 °C
Intake air temperature: 26 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.442 V
Unlearning counter according OBD: 24
selected gear-Bits 0-7: 6
2838 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79049 km
Date: 2022.12.29
Time: 08:49:26
Engine RPM: 2112.50 /min
Normed load value: 87.5 %
Vehicle speed: 75 km/h
Coolant temperature: 46 °C
Intake air temperature: 11 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.277 V
Engine status-Bits 0-7: 3
Engine oil temperature: 42.6 °C
Engine operating condition: Part throttle
Engine operating condition-Test_Program_Channel 87: 6
17895 - Valve for High-Pressure Fuel Pump
P12A3 00 [100] - Stuck Open
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:04
Engine RPM: 1385.50 /min
Normed load value: 82.7 %
Vehicle speed: 35 km/h
Coolant temperature: 56 °C
Intake air temperature: 13 °C
Engine oil temperature: 47.0 °C
17899 - Fuel Rail/System Pressure
P0087 00 [100] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:58
Engine RPM: 1279.50 /min
Normed load value: 89.0 %
Vehicle speed: 0 km/h
Coolant temperature: 53 °C
Intake air temperature: 14 °C
Voltage terminal 30: 12.910 V
Engine oil temperature: 50.6 °C
7697 - Oxygen (Lambda) Sensor B2 S1 Voltage too Low / Air Leakage / Sample Error
P2415 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:31
Engine RPM: 986.50 /min
Normed load value: 16.1 %
Vehicle speed: 25 km/h
Coolant temperature: 54 °C
Voltage terminal 30: 14.418 V
Engine oil temperature: 47.8 °C
Engine operating condition: Idle
Engine operating condition-Test_Program_Channel 87: 5
Driver-side belt buckle status-Bits 0-7: 62
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
7683 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
P2414 00 [101] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 79051 km
Date: 2022.12.29
Time: 08:51:31
Engine RPM: 990.50 /min
Driver-side belt buckle status-Bits 0-7: 61
Readiness: 0000 0000
thanks,
Ben
VCDS readout
4.2 V8 32v FSI - 444 bhp
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- ↳ RS e-tron GT (J1) 2020-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
