2014 sat nav update
4.2 V8 32v FSI - 444 bhp
Rusty Racer
2014 sat nav update
Post by Rusty Racer » Sun Jul 14, 2019 1:30 pm
So after driving across grass fields again I figured it was time for an update and duly purchased the 2019 map via a mate in TPS.
Got home, found the MMI setup menu and selected update but after numerous attempts the sd card can’t be found?
It’s looking like I now require a firmware update also as it may be the original in the car still. Has anyone else come across this, I would appreciate a recommendation for a company who knows what they are doing :D
2018 RS4 B9 Carbon Edition
2014 RS4 B8
Rusty Racer
Re: 2014 sat nav update
Post by Rusty Racer » Tue Dec 24, 2019 10:35 pm
Ended up with wrong map so after getting the right one it’s all sorted FYI
2014 RS4 B8
Flighty
Post by Flighty » Fri Dec 27, 2019 6:17 pm
How much was the SD? I have been trying to do this for some time....
Rusty Racer
Post by Rusty Racer » Fri Dec 27, 2019 9:44 pm
Just over a couple of hundred iirc. Most important thing is to get your current nav details off the car and then get the correct map 😁
2014 RS4 B8
Scub37
Post by Scub37 » Wed Jan 01, 2020 9:05 am
Where did you get the SD card from, Audi are quoting be over £300 to update the sat nav
Rusty Racer
Post by Rusty Racer » Wed Jan 01, 2020 10:37 pm
TPS but unsure of their current retailing policy (they might not be willing to sell to you).
Tbh it was a massive pita and I ended up back at the dealer after I had eaten a big slice of humble pie!
If you go to the dealer they should also update the firmware version and now I guess you get a 2020 map
2014 RS4 B8
Ralpharr2001
Post by Ralpharr2001 » Thu Jan 09, 2020 2:59 pm
I upgraded my firmware and maps in November using these guys with no problems:
https://upgrademyaudi.net/tutorials/upd ... -firmware/
Sensible money for the upgrade. If you follow their guide to the letter works a treat. Did take an hour or two to upload into the MMI. Adam is very helpful if you get stuck.
RS4 (B8), Solar Orange, Sports & Carbon Pack
