Post
by Surrey Sam » Thu Oct 05, 2017 1:44 pm
If its a very rare and infrequent bad change from 2nd -1st only. Then I'm inclined to say that it's just an odd bad gear change, as 1st gear is quite tall. I'm on gearbox #3 and they've all done it. However if you're getting poor quality changes in other gears, humming or buzzing noises, then there could be an issue.
Gearbox Whine - Well my first gearbox was replaced as a result of the centre crown wheel differential failing. This caused a whine that was audible at all speeds and increased the faster you drove. It's an intrinsic part of the gearbox, so required a new one despite the actual gearbox element being fine. Gearbox #2 fitted and this never felt right from day 1, poor quality changes and this time a different low speed whine in 1st gear when pootling around car parks. So this was replaced after 4k miles with Gearbox #3 and gear changes are now back to normal but low speed whine still present. Audi claim this is a characteristic of the car, I was never convinced but other than that, everything else worked fine and I still had warranty.
Engine Surging - Yes, experienced this also and it's exactly how you describe. Most noticeable when pulling onto a motorway and you give it a fair amount of throttle, using the cars torque but not enough to provoke a down change, usually 4th or 5th. It doesn't always happen and is hard to replicate, so usual dealer reply of 'no fault found'. My car did eventually throw some fault codes, so printed them off and handed to the dealership when in for the #2 Gearbox change.
2636 - Low Pressure Fuel regulation
P310B 00 [096] - Fuel Pressure Outside Specification
2638 - Low Pressure Fuel regulation
They replaced a fuel pump, sorry I forget which one, but think it may have been the high pressure one feeding the fuel rail. The fault was never fixed but as it was so infrequent and non-replicable, I just felt that I couldn't fight it. However, the last few months I've been battling with Audi over an engine issue that has happened. The car broke an exhaust valve spring which meant an engine out job to inspect for any further damage. Once given the all clear it was re-assembled and after less than 400 miles, broke down again. Removed and stripped, no fault was found. So Audi asked for re-assembly and further testing, only for them to finally say late last week "New Engine" required. I'm a bit bewildered as to what the fault is right now but will be proposing a meeting once the new engine has been built, sent, and fitted. For those who haven't glazed over and moved on, the car has only done 16,800 miles.
So, my point for telling the above? I'm yet to drive the car enough, to see if the engine surging is still there after the broken engine exhaust valve was replaced. I will now instead, have a new engine to test once the car is eventually back in my possession. So will be intrigued, to see what, if any affect that has had on my two outstanding concerns of - surging and the low speed whine. I'm very, very, sceptical that anything has changed. The saga continues.
