Jacking points
Jacking points
Anyone got and pictures of the jacking points for a trolley jack as I'm going to put my spacers on the car
I've had a trawl thought he net but not found any thing yet
cheers
cheers
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Jacking points
i used the car jack but would still like to know the correct placement for the trolley jack if anyone knows
- Surrey Sam
Re: Jacking points
Don't know the answer but could you not use one of these?
http://www.ebay.co.uk/itm/Rubber-pad-ru ... 418fecd2a8
Re: Jacking points
cheers will get one
Re: Jacking points
In case you are still looking for it, and for other members' future reference.
Re: Jacking points
Which wheel do you have on and what spacer size are you getting?
Re: Jacking points
I have rotors and 10 mm spacers
- Graeme4130
Re: Jacking points
I use the metal seam inside of each wheel as per the diagram a couple of posts up
Re: Jacking points
I used the points as mentioned above with no problems. I did make a tool the same as the rubber one out of wood
I did contact the guy on Ebay as it doesn't mention RS4 fitment and got no answer, however i think you would need a slot of approx 12mm wide by 20mm deep and 110 long maximum if i remember correctly. If you trawl through all the different ads it does tell you the slot sizes
I was going to machine one at work but couldn't find a suitable material
Booner - if you do get round to sussing it order one for me as well and i'll sort you out back in the Ury
Re: Jacking points
Pando
will see how the fitment is and let you know
Re: Jacking points
It doesn't fit.
Better off with attic sheet if neoprene on the jack pad.
Re: Jacking points
you tried these andy?
Re: Jacking points
Aye I've got a couple. The slot is too narrow. I just use them on axle stands on my MK2 golds.
If you have a low profile jack some neoprene or heavy rubber sheet is best really.
Re: Jacking points
Cheers it's ordered now so will ser if I can modify it if need be
Users browsing this forum: Majestic-12 [Bot] and 41 guests
