Timed acceleration runs
- Graeme4130
I know it's not exactly a vbox, but this is the last launch timing I had in my RS4
The app's called dynolicious and when I compared it to vbox data once, it wasn't too far out Temp was 14deg and the road was dry
I'll do the same in the rs5 I have on loan if I get a chance
Anyone else have any data ?
Re: Timed acceleration runs
Only similar data I've seen so far is the Chris Harris rs4 vs s4 test. Impressive Graeme
That is quick!! Maybe sakamino has some time slips- data
it's a lot more accurate than people give it credit for!
This was my best run in the RS3 prior to it having APR' stage 1 map:
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
You can see where forced induction benefits the '3 compared to Graeme's time. I didn't think it would be so pronounced.
200KG extra weight?
Quattro drivetrain losses?
Naturally aspirated vs. Forced induction.
Both using launch control?
Level road?
Level road?
- Graeme4130
There's definitely a fair amount of variables in that comparison. However, I've come against a modded rs3 before in a straight line, and got smokedHYFR wrote:200KG extra weight?
Level road?
Launch control
27 Deg
Relatively flat surface
Dry surface
38/35 PSI tire pressure measured cold in the morning
Full tank of fuel
No passenger, only driver
Minimal luggage
Ignore the higher speed timing. I let off after hitting 180 because I had to turn off Stability control for executing the Launch Control and thought to take it easy.
One more thing, I am on Toyo T1A0 tires. Stock tires for the RS4 at this part of the world.
Good times!! I trust your driving a b8 yes?
Yup, can't wait to test her again with other bolt on parts. Nothing as serious as yours
What did it do stage 1?Macdaddy wrote:it's a lot more accurate than people give it credit for!
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
It was flat road, launch control.
It fairness it averaged out at 4.3 over 4 runs.
I've not managed to run yet since the map however others are quoting times of 3.3-3.6 mapped, i do know those on super bikes don't pull away from you at the lights
- Graeme4130
A fireblade will do 0-60 in 2.8 and 100 in 5.5, so to keep a superbike in view off the lights is veyron fastMacdaddy wrote:It was flat road, launch control.
Almost as fast as a Panigale
Users browsing this forum: AndyBrad and 65 guests
