Exhaust Valve issues???
Posted: Mon Mar 19, 2012 1:23 pm
by biker78
Afternoon All,
Just have a quick question. Whenever I use the S-button and slow down from 4th to 3rd the exhaust valve seems to close and re-open when I slow right down into 1st gear. For example when I slow down for a speed bump, I notice the "metal clanging" noise when the valve opens. Anyone else have this problem (or indeed if it is one)? I can't seem to find any info on how the valve works. I'd have assumed it's open constantly when S-button is pressed.
Cheers,
Chris
Re: Exhaust Valve issues???
Posted: Mon Mar 19, 2012 1:35 pm
by Dave_Hedgehog
i have assumed its vacuum operated like the R32 butterfly valve, but on a switch rather than throttle position
i cant say i have noticed this on mine
Posted: Tue Mar 20, 2012 5:48 pm
by biker78
Well having phoned Audi, apparently they don't know how the valve works either!
All I wanted to know was whether the valve is supposed to stay open the entire time the sports button is pressed? I have to take it in so they can see it for themselves.... seems a bit extreme for just a "yes" or "no" answer!
Posted: Tue Mar 20, 2012 7:52 pm
by Dave_Hedgehog
i would try mine to see if it does it ...
Posted: Tue Mar 20, 2012 10:07 pm
by drybeer
Going back to 2003, and the TT MkI with the 3.2 quattro DSG - the 'worst valve would open full just like you say to make the car burble more as you slow to a stop. Makes pedestrians take notice. I believe it was done on purpose. I suspect it's the same here.
Posted: Wed Mar 21, 2012 8:52 am
by biker78
Well that sounds about right then drybeer. Have to say, it does sound good when it burbles.....although the boy in me would like it to be louder!
Posted: Wed Mar 21, 2012 9:38 pm
by drybeer
biker78 wrote: although the boy in me would like it to be louder!
You can't be driving fast enough...
Posted: Fri Mar 23, 2012 10:25 am
by Stoffle32
dont you think it works in a similar manner to the Rs4 one? When you idling and at a stop, the exhaust valve is open when the sport button is pushed but closes until certain revs then re-opens... so you dont get a drone at low rpm and high way speeds... SO it only opens when really pushing or at a stop when you can physically hear the change
Posted: Fri Mar 23, 2012 7:07 pm
by Dave_Hedgehog
im pretty sure mine got a lot louder as soon as pressed the button even if stationary
Posted: Fri Mar 23, 2012 7:39 pm
by PetrolDave
Dave_Hedgehog wrote:im pretty sure mine got a lot louder as soon as pressed the button even if stationary
That's how the RS4 one works too.
rpm < 1000, valve open - so pressing the S button at tickover opens the valve and makes it louder
3000 < rpm < 1000 AND 3 <= gear <= 1, valve closed
rpm > 3000 AND 3<= gear <= 1, valve open - so in lower gears the valve is only open at higher rpm
gear >3, valve open - so in higher gears the valve is always open
Posted: Fri Mar 23, 2012 8:33 pm
by Dave_Hedgehog
ill test it
give me 3-4 months lol
Posted: Mon Mar 26, 2012 11:07 am
by biker78
PetrolDave wrote:Dave_Hedgehog wrote:im pretty sure mine got a lot louder as soon as pressed the button even if stationary
Cheers PetrolDave.....that's what I was looking for! I think that's the deal with this one. Cheers,
Posted: Mon Mar 26, 2012 6:31 pm
by Moschop5
Yes it does get louder me and Drybeer tested it on one last week..
Posted: Mon Mar 26, 2012 9:15 pm
by drybeer
Moschop5 wrote:Dave_Hedgehog wrote:im pretty sure mine got a lot louder as soon as pressed the button even if stationary
