Sports turbocharger LO500+ Audi RS3 & TTRS
Posted: Thu Aug 18, 2011 10:58 am
by supersi
BorgWarner (KKK) premium quality optimized by Loba Motorsport.
technical specifications
custom "Extended Tip" billet compressor wheel
state-of-the-art compressor wheel geometry
The billet compressor wheel is custom-made. Its shape, geometry and size are unique
Optimized intake coupler for optimum intake-airflow
5-axis CNC modified compressor housing and inner surface for optimum flow in intake and
exhaust areas
5-axis CNC modified turbine housing to fit bigger turbine wheel, to increase flow and reduce exhaust gas backpressure before the turbine
New bigger turbine wheel
XX° grinded runner (wheel) to help increase the flow capacity and reduce exhaust backpressure
5-axis CNC modified manifold inlet to increase flow
optimized clearances in compressor housing and turbine housing
modified actuator
reinforced thrust bearing
balancing of single parts and the basic unit
500+ HP capable
We can also supply a Optimized intake coupler for optimum intake-airflow to the turbo charger (extra charge!)
all parts are made and designed in germany.
http://www.facebook.com/media/set/?set= ... 915&type=1
Re: Sports turbocharger LO500+ Audi RS3 & TTRS
Posted: Fri Apr 26, 2013 11:06 am
by scaghead
Amd are fitting one of these to someone's 3 soon...anyone on here?.
Posted: Mon Sep 30, 2013 10:02 pm
by babyboss
any fitted these - results ?
