RS3 TC light question
My first post on here (I am normally on the RS6 forum).
My wife has an RS3. Around a month ago she had the car serviced. They replaced the rear tyres and ever since the car has felt slightly twitchy and the TC light flashes regularly. For example when changing lane on a motorway at 50-70 mph or cornering at normal speeds. It does not feel right.
Anyway, our local Audi dealer has the car back now. They are claiming that the front tyres are worn and the difference in grip/circumference between the fronts and rears is the cause.
I am not convinced, especially as the fronts are (depending on who you listen to) 3.5 mm-5 mm. They will only check the geometry once the new tyres are on.
I am not convinced. I have had several RS Audi's and never had this problem.
So my question is has anyone else had a similar issue? I have told Audi they can replace the tyres but if the problem has not gone away I am not paying as the current tyres still have several months life left in them.
- 2nd Gear
Re: RS3 TC light question
The different circumference issue may be valid.. Different tyres will actually give different overall wheel diameters.. I don't know how sensetive the calibration is to these kinda things, but if your rear wheels are spinning at a significantly different speed to the fronts, the software may detect it as wheelspin.. Not good long term on these systems.
I think the easiest and most obvious thing to look at though is what brand and model are the front tyres vs the rear? If they've put on the budget of the budgets (as audi had done to the previous owner of my car) then the rear tyres may genuinely be loosing traction!
2007 RS4 Saloon; Mugello Blue
I would not be relying on Audi to change the tyres in the first place, take it to a reputable tyre company, have them start with the basics such as what pressures are in the front and back, I find between 37-39 seem to work best. You then need a four wheel alignment doing, its usually free to check if its out, it only costs if it needs adjustment.
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Wow you paid audi for tyres! There is your first mistake!
Even kwik fit are better!
I took my R8 wheel to kwik fit as had a leaking valve, they tightened it up and sorted it foc
Audi would have charged me for a brand new TPMS sensor and 2hrs labour
If I had wanted to know where to source cheap tyres then the title of my thread would have been just this.
Thank you anyway for your insightful and helpful reply.
You are welcome
- PetrolDave
The TC is triggered by differences in rotational speed of the wheels as sensed by the ABS sensors, so if the front tyres are worn enough for the radius to be different enough from the rear tyres (a different make of tyre may exaggerate the difference) then it's entirely possible for the TC to be triggered.
So I wouldn't rule out the dealers explanation...
- Dave_Hedgehog
- 5th Gear
Whilst i do not dispute this everything i have ever read has indicated haldex is not tyre diameter sensitive, if i remember correctly it allows up to a 5% difference (+/- 3%)PetrolDave wrote:The TC is triggered by differences in rotational speed of the wheels as sensed by the ABS sensors, so if the front tyres are worn enough for the radius to be different enough from the rear tyres (a different make of tyre may exaggerate the difference) then it's entirely possible for the TC to be triggered.
I have 7mm on my fronts and 2.5mm on my rears and have no TC light activity at all, and there is a 0.7% difference front to back before you start because of the different tyre sizes
you also no longer need new tyres all round to do the geometry you also should not pay the fortune audi will charge you to do it, look around for someone with a hunter all wheel alignment system, its much more accurate and faster than the older ways of checking a cars geo and should only cost around £75
http://www.youtube.com/watch?v=CGTHN3G_DR8
check the tyre pressures as well, i have never known an audi dealership to get them right, i have often come away with a default pressure for a normal car lol
i also dumped the conti tyres as they are terrible, MPSS's are vastly better imo
The Hedgehog, creator of RS4.org, back in of the RS fold yet again, third time lucky
- PetrolDave
Diameter differences triggering the TC is nothing to do with Haldex, the same thing can happen on a Torsen equipped car, or even a vehicle with a Salisbury (or any other kind of) centre diff. If the ABS sensors say that the rotational speed between wheels is great enough then the TC will kick in - what I (we?) don't know is what rotational speed difference is needed for that to happen, so I (we) can't calculate what that means in terms of difference in wheel diameter. And there's always the possibility that the ABS software has an in-built factor for the normal diameter difference between front and rear wheels.Dave_Hedgehog wrote:Whilst i do not dispute this everything i have ever read has indicated haldex is not tyre diameter sensitive, if i remember correctly it allows up to a 5% difference (+/- 3%)PetrolDave wrote:The TC is triggered by differences in rotational speed of the wheels as sensed by the ABS sensors, so if the front tyres are worn enough for the radius to be different enough from the rear tyres (a different make of tyre may exaggerate the difference) then it's entirely possible for the TC to be triggered.
TC is a piece of complex software, and I (we) just don't have enough knowledge of the detailed parameters used in the RS3 to say whether it is or is not being triggered in this case. So it has to be a possibility, and we cannot say that the dealers explanation is wrong - because it MIGHT be right.
But it might not be...
- Dave_Hedgehog
- 5th Gear
hmmm sainsbury diffPetrolDave wrote:Diameter differences triggering the TC is nothing to do with Haldex, the same thing can happen on a Torsen equipped car, or even a vehicle with a Salisbury centre diff.Dave_Hedgehog wrote:Whilst i do not dispute this everything i have ever read has indicated haldex is not tyre diameter sensitive, if i remember correctly it allows up to a 5% difference (+/- 3%)PetrolDave wrote:The TC is triggered by differences in rotational speed of the wheels as sensed by the ABS sensors, so if the front tyres are worn enough for the radius to be different enough from the rear tyres (a different make of tyre may exaggerate the difference) then it's entirely possible for the TC to be triggered.
- PetrolDave
http://ollr.createaforum.com/technical- ... tep-guide/Dave_Hedgehog wrote:hmmm sainsbury diff
- Dave_Hedgehog
- 5th Gear
lots of bits of metal and then ZZZZZZZZZZzzzzzzzzzzzzzzzPetrolDave wrote:http://ollr.createaforum.com/technical- ... tep-guide/Dave_Hedgehog wrote:hmmm sainsbury diff
- PetrolDave
Some real engineering for a change, not just this software stuffDave_Hedgehog wrote:lots of bits of metal and then ZZZZZZZZZZzzzzzzzzzzzzzzz
I've spent the last 2 weeks writing LabVIEW test software so it made a real change today to work on a laser powerful enough to blind you instantly - that's when engineering becomes interesting
- Dave_Hedgehog
- 5th Gear
i actually do get the attraction of computer free mechanical cars, modern cars are just to bloody competent and to damn easy to drive, the M235i i drove recently was well setup and utterly boring, like playing a computer game, the A45 AMG is the samePetrolDave wrote:Some real engineering for a change, not just this software stuffDave_Hedgehog wrote:lots of bits of metal and then ZZZZZZZZZZzzzzzzzzzzzzzzz![]()
what did you melt with the laser when no one was looking
- PetrolDave
My boss might be reading thisDave_Hedgehog wrote:what did you melt with the laser when no one was looking
Users browsing this forum: No registered users and 39 guests
