Yikes, it only went in for a service
Posted: Mon May 16, 2011 12:38 am
Before my garage undertook the service they had a quick look around to see what needs doing....
New cooler header tank as the current one is split on the bottom side
Near side CV boot split but not right through just yet
New set of rear disc and pads - both sides
Off side front O2 sensor error
Upper arms both side - offside gone completely, near side on its way out
Near side swirl actuator - ball joint broken off
Blowing exhaust from near side manifold -> cat - caused by the lower support bolt shearing off so the weight of the front cat is hanging from the manifold bolts
2 Front new tires
Hmm in total just shy of 2k once vat is added including the service
, didnt to tell the missus or that car would be gone by now.
Will get it all done over time, however they did say depending on the manifold part if they cannot fix the supporting bolt or the manifold is damaged it could be engine out job, gulp!
Sniff
2 Front new tires
Sniff
